It depend on the shape you want to turn simple shape yes it would be possible, you may need to experiment with the tool height unless you make a tool rest and use hand tools.
Woodturning tools are normally used with a bevel and it ideally need to be rubbing just to the point of cutting to give a clean cut.
As also stated some woods have a high content of tannin so an immediate clean up is needed once finished.
If it is just a problem then finding someone into woodturning close to you to do the job. You can also find woodturning clubs worth a try there are many around the UK have a look HERE from the AWGB
What is it that you wish to turn.
This is something I know a little about you can see some of my work HERE
From a woodworker who also wants to get into model engineering
