Posted by Christopher judd on 19/08/2019 12:26:25:
Not sure I understand are you saying just centre using the 3 jaw chuck after checking alignment?… Also what then is the purpose of the faceplate and dog as the 3 jaw can be used instead/
Chris
Yes, because – within reason – the exact placing of the centre holes may not matter much. When turning between centres with a dog the axis of rotation is the line between the two centre points, nearly independent of any chuck run-out. If top accuracy or a known taper is to be cut it can be achieved by nudging the tail-stock sideways while testing with a DTI.
How easy it is to set and reset a tail-stock may be the sign of a quality lathe. The adjustment on my mini-lathe was distinctly crude and could take ages to get right. Not sure what a Sherline is like, but many lathe owners avoid altering tail-stock alignment if they can!
On a big lathe, centre drills are the best way of drilling the holes. They put a chamfer on the end of the hole that the well-greased centre runs on. Watchmaking may be too tiny for a centre drill in which case the centre is caught with the sharp point of a graver. As the centre of axis has no rotational velocity, the graver tends to find it.
Personally I've yet to use a face-place or a dog on any of my adventures. Much quicker to use a chuck or collet unless there's good reason not to!
