Having spent many a long year getting frustrated by countersink tools that never seem to work well for me, I recently discovered something that I should have realized a long time ago. It started when I needed to make a number of countersunk holes that went deep enough to sink the screw heads about 1mm below the surface.
I had recently bought a set of 90 degree spotting drills from the place I cannot mention lest I be struck down, and realized that they make ideal countersinks. I was using M6 screws which had a maximum head diameter of just under 12mm, so by using a 12mm spotting drill I produced very nice countersunk holes to the correct depth. The cutting was very smooth indeed and much nicer than a conventional countersink bit.
I am probably the last person to realize this use for a spotting drill, but in case not, I thought I would give it a mention.
Doug
