Using nitrile balls in clack valves
Home Forums Locomotives Using nitrile balls in clack valves
  • #646001
    Redsetter
      @redsetter
      Stainless balls are absolutely fine in bronze clack valves and they last indefinitely.
      Edited By Redsetter on 20/05/2023 19:09:57
        One thing that can be done with a metal ball that Nitrile can't do, is to whack one with a hammer into the seat so it deforms to fit the ball accurately. Replace the whacked ball with a new one because it probably squished out of shape and is no longer a sphere.
        Beware – I've never tried it!
        Edited By SillyOldDuffer on 20/05/2023 19:18:24
        #646015
        HOWARDT
          @howardt
          Many years ago I worked with high pressure airless paint spray units, 2500psi. These used a small check valve, the ball material depended on the paint intended to be used, either carbide or stainless steel. We used to put a steel ball in and strike it into the seat to create a perfect seal then build the check valve with a new ball. Some of our other pumps used glass balls in the check valves but these were 1/2” in diameter. Once seated properly the check valves rarely gave any trouble.
          #646025
          Paul Lousick
            @paullousick59116
            I have been using ceramic balls in the check valves in the water pump (bronze housing, shaft driven) of my traction engine for the past 5 years with no problem. (The boiler clacks use winged, taper type).
          Home Forums Locomotives Topics
