Using nitrile balls in clack valves
Home Forums Locomotives Using nitrile balls in clack valves
Viewing 25 posts - 1 through 25 (of 29 total)
  • #157133
    Ianmac
      @ianmac
      Recently been bothered with unreliable injector operation which I eventually traced to the clack valve on the injector feed to the boiler (GWR 5" Pansy). Despite replacing this with a a self made and purchased unit, using both SS and Bronze balls I failed to get a perfect seal. My eventual cure was to use two clacks, one at the boiler and one fitted close to the injector.
      The injector now operates to my satisfaction.
      Looking further at this issue,I wondered if there was any mileage in using nitrile balls in these clacks.
      No one in my club has any enthusiasm for nitrile but cant say definitively why.
      Can anyone give me an opion on the use of nitrile ?
      Ianmac
        @ianmac
        #157147
        michael howarth 1
          @michaelhowarth1
          They have always worked well for me with a perfect seal every time. I have seen it written that they might extrude into the hole that they are supposed to seal but it has not happened to me and if it did I should just replace it, possibly with a bigger ball.
          Mick
          #157150
          michael howarth 1
            @michaelhowarth1
            Further to the above, when using a nitrile ball, I have found a note to myself to use the next size up. I think that I was advised this by the supplier.
            Mick
            #157151
            John Baguley
              @johnbaguley78655
              I seem to recall that Nitrile balls should be used with a conical seat as the normal sharp edge seat used for metal balls can damage the soft rubber?
              michael howarth 1
                @michaelhowarth1
                That seems like a very good idea John, and one that I shall use in the future.
                Mick
                #157176
                Boiler Bri
                  @boilerbri
                  I have not used nitrile, but I have used the stainless steel ball. I always give the ball a tap with a punch and hammer to seat it in the base of the valve. I put a nut on the thread and stand it on the surface plate. This works very reliably.
                  In the BIG world of steam boilers I have neve known rubber be used anywhere?
                  #157179
                  Ianmac
                    @ianmac
                    John thanks for the hint on using a conical seat.
                    I'll try one with a seat edge cut to as close as I can get to the angle of the ball circumference at point of contact with the clack seat.
                    I note that there are also different hardnesses of rubber avaiable from the pro suppliers. I can only find any comment on the rubber parameters on the Reeves site but still looking
                    Ian
                    #292431
                    robert bailey
                      @robertbailey64547
                      Re the big world of steam boilers……………..Latex rubber was used extensively for the flap valves in air/steam pumps and also rhinoceros hide etc etc etc Willy Bailey
                      #292437
                      vintagengineer
                        @vintagengineer
                        Ball valves are used in hydraulic systems and if they didn't seat properly we used use a brass punch and give the ball a hefty whack! This usually sealed the valve.
                        #292455
                          Tip.
                          Whack the ball to form the seat. Then replace the ball with on that hasn't been deformed by being whacked.
                          #292532
                          Ian S C
                            @iansc
                            I may be wrong, but I think I read somewhere (prob ME) of someone using SS, or bronze balls, and an O-ring as the seat.
                            Ian S C
                            #292555
                            Brian Oldford
                              @brianoldford70365
                              Posted by Neil Wyatt on 07/04/2017 18:37:43:
                              Tip.
                              One of LBSC's tips from (I think) Shop, Shed and Road. It may also be in the Tich book too.
                              #292557
                              John Baguley
                                @johnbaguley78655
                                I've used O ring seats for clack valves with success after seeing an article by Jim Ewins on his Loadstar locomotive. Just make sure that the O ring is retained so that it can't lift with the ball. They make good check valves for lubricator oil supplies.
                                A commercial design of clack valve uses a poppet fitted with an O ring that seals on a flat seat.
                                A possible alternative to stainless balls is silicon nitride (ceramic) balls. These are said to be harder than and have a better surface finish than steel. Not my idea but Roger Froud on the MECH forum is using them in his Speedy build. It will be interesting to see how they work out.
                                nigel jones 5
                                  @nigeljones5
                                  I used to use them till one got irretrievably pushed into the water pipe. I only use metal now!
                                  #293436
                                  Clive India
                                    @cliveindia
                                    Posted by Brian Oldford on 08/04/2017 16:14:42:
                                    Tip. Whack the ball to form the seat. Then replace the ball with on that hasn't been deformed by being whacked.
                                    Come on folks, not a very good tip is it – and it mostly does not work well enough for me.
                                    O rings are the answer I think. Either O ring on a top hat with fluted shank or ball sitting on an O ring works best for me.
                                    #293437
                                    Manofkent
                                      @manofkent
                                      Can anyone recommend a Uk supplier of Viton rubber balls suitable for clack valves please?
                                      Thanks
                                      Steamgeek
                                        @steamgeek
                                        Nitrile balls have a habit of floating, problem becomes obvious with vertical clacks below the boiler water level when the boiler is not under pressure they will leak. Normally once pressure starts to build ( 3-4 psi ) they seal effectively. A solution to this is have a small screw in the top of the clack valve to force the ball down when not under pressure and stopping any leaks. Challenge here is to remember to unscrew it before running or you quickly start wondering why your injectors will not work.
                                        #293440
                                        Steamgeek
                                          @steamgeek
                                          Sorry too quick on the post button
                                          Maccs Models normally have a good supply at reasonable prices
                                          #293441
                                          Clive India
                                            @cliveindia
                                            Polly Models stock 1/8, 5/32, 3/16 and 1/4 viton
                                            7/32 is difficult to find in UK – try US.
                                            Edited By Clive India on 15/04/2017 11:30:03
                                            #293490
                                            Manofkent
                                              @manofkent
                                              Thanks both.
                                              Polly models has viton balls.
                                              Macc models looks like Nitrile only.
                                              Advice much appreciated.
                                              Nitrile balls are a bit cheaper. I will use them in the tender pump and axle pump.
                                              Viton have a higher temperature rating so I will use these for clacks, snifter valve and whistle valve and hope I can keep them separate from the Nitrile ones.
                                              Edward Lewsey
                                                @edwardlewsey56991
                                                Hi all, novice here.
                                                Just found this thread. I am trying to repair a leaky old clack valve. It's a phosphor bronze one fitted directly to the boiler. Took apart to clean in some acid and found the ball was a nitrile one with a nice indent all around it, presumably where it was being worn all these years.
                                                I have an urge to replace with a metal equivalent (or at least try to)- my question is whether I should try a stainless steel ball or a bronze ball as a replacement- would it matter or make much difference?
                                                If I did use steel, would this react with the bronze fitting? The reaction charts are a little confusing for a begginner!
                                                Thanks!
                                                Ed
                                                #645992
                                                  Three advantages of Nitrile:
                                                  • the ball wears out rather than the valve seat.
                                                  • the material squishes slightly into the bed and makes a better seal than a metal ball, especially if the valve seat is a bit manky
                                                  • there's no risk of electrolytic corrosion damaging the seat
                                                  Replacing a nitrile ball with metal increases the chance of a weeping leak in the short term, and maybe much worse trouble later due to physical and corrosion damage.
                                                  I'd replace the ball with new Nitrile. The designer probably selected Nitrile rather than metal for sensible reasons. All design is a compromise. In this example the ball doesn't last forever and has to be replaced, but that's less painful than having to replace the whole valve.
                                                  Edward Lewsey
                                                    @edwardlewsey56991
                                                    Posted by SillyOldDuffer on 20/05/2023 18:03:42:
                                                    That all sounds very sensible! I'll probably pop in a fresh nitrile one then. Thanks!
                                                    #645999
                                                    Harry Wilkes
                                                      @harrywilkes58467
                                                      My fellow club members have mixed views on the use of nitrile ball in clacks as they have been know to get pushed into the boiler that said I have used nitrile ball in my injector clack as I need to make a new one I ran my 3" Burrell all last year with a nitrile ball and replaced it with a new one this year. I may get shot down by I'd used SS or PB balls unless you have a problem with them seating
                                                      H
                                                    Home Forums Locomotives Topics
