Hi All
For scraping I use Windsor and Newton Prussian Blue artists oil (not acrylic) colour. It is sold in different grades, it pays to pay a little more for the best quality, not student grade. A small tube will go a long way.
While you are at the artists supply shop pick up a small rubber print roller. Mine is about 25mm wide. (One that has good centered bearings or that will be your first job to rectify) otherwise it will not roll easily; the oil colour is very slippery on glass and you will get colour banding. I know that from experience. You also need a small glass plate.
The method is simple; put a tiny dot of oil on the glass and roll an even film out over the surface, as fine as needed. Then use the roller to transfer the colour to the work. If the scraping is at the early stages you can use more. As it progresses you need less, the objective being the thinnest film possible. You may need to thin the colour with a little linseed oil. At the end of the day clean the glass and the roller for the next day.
The only difficulty arises when you can’t reach the work with the roller then I use my finger!
Near the end of the scraping you get to a point where the film of colour is too thick to work effectively. At that point rubbing the surface with methylated spirit may help it depends on the steel, if it goes dull you can then very slightly rub the surfaces together and you will get bright spots where they touch.
The bible for me is this book. One day as is the norm I was browsing at the back of a secondhand bookshop, I found a copy. As all will know in this place in ANY secondhand bookshop the engineering section is at the back of the shop on the lowest shelves If at all….Bah Humbug.
machine tool reconditioning by edward f. Connelly
Maybe your local library has a copy. I have seen it on Amazon.
Cheers
Edited By John McNamara on 06/07/2011 01:49:21
Edited By John McNamara on 06/07/2011 01:51:39
