Using magnets
Using magnets
Home Forums Workshop Techniques Using magnets
  • #403493
    Paul M
      @paulm98238
      I recently pulled apart a PC hard drive (not solid state) and discovered two very strong magnets.
      I have used them frequently for holding ferrous parts together when marking out and spotting for drilling. They are small flat and very useful.
      Not something I would have thought of using in the past, but worth retrieving if you have a dead hard drive.
      Paul M
        @paulm98238
        #403495
        steamdave
          @steamdave
          Also, the ball bearings are top quality.
          The Emerald Isle
          #403512
          Ian S C
            @iansc
            Also the ballraces in VHS recorders/players, including some with as small as 3 mm bore in the nylon tape guide rollers, the others are usually 6 mm bore.
            Good ferite magnets from old modern speakers, and micro wave ovens.
            Ian S C
            Edited By Ian S C on 04/04/2019 10:51:15
            #403514
            ega
              @ega
              Posted by steamdave on 04/04/2019 09:34:07:
              The Emerald Isle
              Are they air bearings today?
              #403533
              Ian P
                @ianp
                Hard disk drive bearings are a whole technology in themself. Lots of different types but I presume development (to reduce cost and increase performance) has slowed as solid state disks become cheaper.
                Quite a lot of drives use what I would describe as a plain bearing but its one that can run quietly and continuously at high speed for years with no maintenance. Looks to be done by high precision machining and some sort of hydraulic/dynamic control of a the miniscule amount of lubricant.
                HDDs can be a good source of very high quality light duty ballraces but the older the drive is the more likely it will contain parts that are re-usable, modern drives are so highly integrated that the bearings tracks are machined directly into the shafts and housings.
                Ian P
                #403551
                V8Eng
                  @v8eng
                  Posted by Paul M on 04/04/2019 09:19:15:
                  Do not let those magnets get together because separating them needs a lot of force. Don’t ask!
                  #403555
                  Nicholas Farr
                    @nicholasfarr14254
                    Posted by V8Eng on 04/04/2019 13:37:43:
                    Hi, and watch your fingers, as those magnets have quite a sharp snap when they get close to iron or each other.
                    Regards Nick.
                    Edited By Nicholas Farr on 04/04/2019 14:16:54
                    #403560
                    Nigel McBurney 1
                      @nigelmcburney1
                      Dont get them near to bank cards or other cards as they will wipe the magnetic stripes. I worked for a long time with hard drives,I was working onnce with an actuator engineer who held an actuator up close to his chest to show me some details and promptly wiped out the magnetic stripe on his security pass.
                      #403562
                      Speedy Builder5
                        @speedybuilder5
                        I had some about 4" x 2" x 1" however made the mistake of not using some of the soft iron in the drive as a keeper. Over about 10 years, they lost their strength.
                        #403565
                        I.M. OUTAHERE
                          @i-m-outahere
                          Here is a useful tool you can make using the magnets you have collected .
                          Ian P
                            @ianp
                            Posted by Speedy Builder5 on 04/04/2019 14:46:35:
                            Were they rare earth magnets?
                            When installed in the hard drive they would not have had a keeper so loosing a significant amount of strength in only 10 years is unusual.
                            Ian P
                            #403596
                            Robert Atkinson 2
                              @robertatkinson2
                              Drives, including older 51/4" ones have other useful parts. The disk platters make good minature surface plates and the spacers between them, tubular paralells or gauge rings (but light alloy not steel) CD-ROM drives also have nice precision ground and polished rods in pairs that the optcal heads run on.
                              Robert G8RPI.
                              #403597
                              Robert Atkinson 2
                                @robertatkinson2
                                Robert G8RPI.
                                #403628
                                vintage engineer
                                  @vintageengineer
                                  When I worked in the backrooms of a well know bank, we used to remove the hard drives from all the computers we sold or scrapped and smashed them with a large hammer on a RSJ! I still do it when I scrap a computer.
                                  #403736
                                  Ian S C
                                    @iansc
                                    To avoid damage to you or the magnet, and make it easier to get apart, always slide them together, it's easy to trap a little bit of flesh if the magnets have nice square edges.
                                    Ian S C
                                    #403741
                                    not done it yet
                                      @notdoneityet
                                      Magnets? Look up the ones that go into many home brewed wind turbines. Check out the holding power of one magnet and then consider the pulling force of two discs with perhaps a dozen or more magnets on each disc! The only safe way is to jack the together or apart using threaded rods and nuts, or similar.
                                      #403822
                                      I.M. OUTAHERE
                                        @i-m-outahere
                                        I have a 50sq x 40 mm thick neodymium magnet and i treat that one with respect i can tell you ! I was using it to hold something in place for welding and was returning it to shelf where it lives , as i walked past my steel workbench ) not paying attention as usual ) the hand carrying it got close enough for the magnet to pull my hand into the bench and clamp it there ! It was like i had belted my hand with a lump hammer !
                                        #403827
                                        Boiler Bri
                                          @boilerbri
                                          I use small 15mm x3 mm magnets with a 2kg hold to hold things like Allen keys chuck keys and spanners.
                                          Very usefull items.
                                          Bri
                                          #403914
                                          mark costello 1
                                            @markcostello1
                                            I have about 12" of hard drive magnets, cannot get another within about 6" of it or they get really friendly and will shatter one or two when they meet.
