Posted by JasonB on 21/09/2020 17:19:50:
Simple rule of thumb is that when using the full width of the cutter don't use a depth of more than D/4 that's diameter divided by 4. You can go a lot more than this particularly as cutter dia increases but stick to D/4 for now.
So for your 1mm dia cutter you could go sideways if milling the half circle in say 0.2mm thick brass shim using a single pass but would not want to do that if it were 3mm gauge plate you were cutting. Even if plunging don't do it in one go with a small cutter like that gradually move the work sideways say 0.1mm per plunge
Either way do as suggested in the other thread and drill a 1mm hole then file or mill back to half way.
Edited By JasonB on 21/09/2020 17:34:59
Thanks Jason but although this is related to that thread this post is for a different purpose it is for milling in small radius in a cutter to improve accuracy of milling. Up to I would guess 4mm then moving the end mill out straight to leave parallel front edges during production stages. So in this case drilling a hole is not going to work on its own.
For example if I wish to put a 3mm radius on the end of a 6mm square piece of silver steel I could align the cutter above the stock and mill down but there is a remnant at the front to remove which to date it seems in error I have removed by moving the end mill though the entire 6mm thickness.
Hope all this makes sense, if not a will put up a drawing.
Chris
