I want to run a Stuart S50 on compressed air, but only want a small, quiet compressor, as it will be kept in the house. It will be run at very low speeds, & with no load.
If the engine runs freely when turned by hand, will an aquarium pump give sufficient power, – there is a full Stuart Beam on youTube being operated by this method.
If so, what power of compressor will I need to give 10-20 PSI, as aquarium pumps are rated in litres per hour ?
Any help will be appreciated.
Mike.
