Hi folk,
Thanks for the replies. Some comments.
Halogen heating.
SWMBO appears to have been brain-washed into thinking these things are any good and has been buying them left, right and centre. For myself, with an electrical background I fail to understand how a heater with (say) 400/800/1200 watt ratings can even begin to compare with say a bar fire with a 1000/2000/3000 watt rating. I also find them rather bright which suggests to me a loss of power in the form of light. But, I freely admit, I don’t know how they are supposed to work.
Electric loading.
I have a 20A, say 4700W, max loading for the garage. With the 2KW fan heater, lathe at 550W, two lamps of 60W, lathe & miller heaters of say 50W, I’m left with 1980W which means that for safety (of the fuse) I’m practically limited to say an extra 1K W of heating. As it happens I do have an ancient 1KW electric convector heater presently residing in the caravan but due to be replaced by one of SWMBO’s halogen heaters. No doubt that could be pressed into service in the garage.
Condensation.
I realised early on that I wasn’t going to be able to easily overcome the problems of a single skin garage with a flat roof with a propensity for leaking. I therefore used to spray the lathe with WD40 – messy and smelly. Then I discovered self-regulating heaters so I added a couple to the lathe and lo and behold no more condensation, no rust and the lathe never felt to have that bone chilling cold feel about it. And no more WD40!
Now I was aware of the possibility of extra condensation, hence my intention was to use the gas heater to initially raise the air temperature to something more tolerable and then revert to pure electric heating. Apart from anything else, I rather suspect that 3.7KW of heating might reasonably quickly become intolerable!
Butane v Propane.
Although I have the 6Kg popane bottle, the fittings are totally different inasmuch as the propane is screwed requiring the use of a spanner whilst the caravangas butane bottles are push fit and lever lock if that makes sense. I think therefore that I need to have one or the other, not the possibility of either. And as I’ve already mentioned, having looked into the costings, I rather suspect that I would be looking at the best part of £100 or so to set up propane heaters. I do not think it justified for the odd occasions it may be of use. That’s why I decided against propane.
Semi-permanent background heating.
In my case that would be money thrown away due to the heat loss through the single skin brick walls, the single skin flat roof, and all the ill-fitting doors & eaves. It would be nice to have that luxury, but it is, after all, a garage and at some time in the future, later rather than sooner I hope, it will have to be cleared and then be available for future owners to use as a garage. Which rules out converting it into a nice habitable room.
Heating the butane bottle.
I first came across this idea some 50 years ago when a scoutmaster talked about standing butane bottles on a lit paraffin Primus type stove in winter. I hadn’t said anything because of the safety implications,but had wondered about pointing the fan heater at the bottle from a few feet away.
So back to my original query. What does anyone think about warming the butane bottles slowly in the house, say overnight, and then using alternately? How long will they last before stopping working?
Peter G. Shaw
