Thanks for all the feedback everyone.
My cylinder is a fairly large green steel one (and weighs a ton!) that came as part of the deal with the BBQ. Although the BBQ stays outside under its cover – I always detach the cylinder and store it on the garden shed (upright on a small sack trolley).
I've been on domestic duties so far today (post Christmas clean up – trips to Tip etc.) but will go and look at it again later. I'm pretty certain the regulator is on the BBQ hose end (rather than the cylinder) and assuming it's a straight through connection – a £10 "clip-on" adaptor sounds like the best solution as opposed to another £50 odd for a new propane cylinder (deposit & gas).
If I understand Clive's posting correctly, I can just "nut" the adaptor up to the existing Bullfinch 4-bar regulator & hose and leave it on there permanently. No one will be using the torch except myself and I'm not going to be unscrewing anything whilst it's still attached to the cylinder that's for sure!
If I was starting from scratch, I would probably get a "proper" (red) propane cylinder and use screw-on type regulators (as I understand the propane gas might be cheaper that way) but I'm not and I don't use that much gas either. I do have other gas appliances but they are either butane based or use disposable bottles. So the Bullfinch and BBQ are going to be the only appliances that will need the propane cylinder in the foreseeable future and the adaptor does seem the easiest/cheapest route…
Thanks again for your thoughts on this – I will report back when I finally get this sorted out and have tried the Bullfinch out.
IanT
