Hi all,
I have a background project to fit an Ainjest high speed threading unit to my lathe. Both the lathe and the Ainjest unit are imperial, so cutting imperial threads should be no problem. Just follow the instructions in the manual!
Within the QC gearbox on my lathe there are conversion gears for cutting metric threads. Nowhere can I find a 127 tooth gear in the system, so I am assuming that the ratio used is not exact, but is one of the very close approximations. As is normal, the advice for cutting metric threads on an imperial lathe is to leave the half nuts engaged and reverse the lathe back for the following cut. This is not possible with the Ainjest unit, as it includes an automatic knock off at the end of the thread.
There is a piece of equipment, called a Metradial, that can be used in conjunction with the imperial Ainjest unit to cut metric threads. I assume that this is just a fancy thread dial indicator that allows you to keep track of the starting position. The company in the UK that sells the Metradial seem to be useless, no response to emails and no ‘phone number. Clearly they don’t want my business, so they’re not going to get it.
In essence the problem is how to get the lathe spindle and leadscrew back into the alignment they were originally in, for subsequent cuts. I’m not going to bore you with the number theory behind this, but in essence I think that for cutting a 1mm thread (with a 1/4″ pitch leadscrew) the alignment should be exact for every 127 revolutions of the spindle.
But, there’s a catch here. The conversion factor in the gearing is not exact, so the result will in reality be close, but not perfect. This is hinted at in the Metradial instructions, where there are correction factors to be applied if you are a bit slow in re-engaging the half nuts.
So, my idea is to return the lathe to exactly the point it was for the first cut. There are two things that need to be set. One the position of the tool, and second the alignment of the spindle and leadscrew.
Positioning the tool is easy, using a bedstop against the saddle. For aligning the spindle and leadscrew I propose fitting a rotary encoder to the spindle and counting the number the number of revolutions. If I then reverse the lathe and take the count back to zero, the spindle and leadscrew should be in the original alignment.
So, I have a couple of questions:
Has anybody used an Ainjest unit, and can give me some general pointers as to their use?
For cutting metric threads, will my idea work, and if not, where is the flaw in my logic?
Thanks,
