Can I suggest that crimping is for factory work – with accurately controlled presses and precision dies. And the same size wire and connectors every time. Our workshops are quite different. Not only that, the best crimped connection still has holes between the wires, which can fill with water (which is often not pure water). This can cause corrosion inside the fitting, and this is very awkward to rectify.
Soldered joints, with a manual crimp first to hold everything firmly in place, are better in our varied environments (and sometimes out in the snow.)
Only my views, after about 40 years of doing it successfully.
Cheers, Tim
