Using a brake cylinder
Home Forums Materials Using a brake cylinder
  • #420839
    Nathan Sharpe
      @nathansharpe19746
      Just a general question. Has anyone used or thought of using a vehicle brake cylinder in their modelling? Nathan.
      Nathan Sharpe
        @nathansharpe19746
        #420841
        Mike Poole
          @mikepoole82104
          What did you have in mind?
          #420842
          peak4
            @peak4
            I used a Landrover one as a universal head to hold end mills for sharpening on my Clarkson..
            A bit rough and ready, but sufficed for several years.
            Next plan, when I get round to it, is to source a slightly larger clutch slave cylinder to make some top hat bushes to allow the use of my ex-brake slave cylinder end-mill collets with my larger proper universal head.
            Bill
            Edited By peak4 on 24/07/2019 23:44:21
            #420847
            Nathan Sharpe
              @nathansharpe19746
              Mike, I was thinking about a traction/steam cylinder. Much modification but is it possible? N
              #420883
              Howard Lewis
                @howardlewis46836
                A clutch slave cylinder will have a blank end and an inlet port at the other end. There may be enough "meat" to drill for ports to the valve face / bore at the other end. A drum brake slave cylinder is likely to be open at both ends with a central inlet port.
                Hopefully, the material will be cast iron, rather than light alloy.
                The material should be capable of withstanding far higher pressures than those seen in a model loco, or road engine.
                #420887
                John MC
                  @johnmc39344
                  Was there a design for a Robinson type hot air engine using a car brake cylinder described in ME some years ago?
                  May have used a beer can for the displacer, (I could be wrong about that).
                  Ian S C
                    @iansc
                    According to James G, Rizzo, there is a brand of drink in UK that uses a stainless steel can this is used in at least one of his engines that was featured in Model Engineer. Aluminium cans are far from ideal for use as displacers.
                    I have a brake cylinder somewhere in the workshop waiting for a motor to need a cylinder, I have decided that to make the best use of it, I will turn the outer diameter, and use it as a cylinder liner. I was looking at a (full size) cylinder liner in the junk box the other day, I think that if I cut it in half I might make a Ross Yoke type ALPHA motor with about a 4" bore. The liner needs reboring (that's why I'v got it).
                    Ian S C
                    #421099
                    DiodeDick
                      @diodedick
                      I used a cast iron double-ended rear brake cylinder from a Hillman Avenger as the body for a baby VDH for my Norfolk (nee Flexispeed Meteor) 2" x 12" lathe. I had to cut off the bit that takes the brake pipe and bleed nipple and fix the rest to a piece of 1/4" plate from below. There might have been some packing to get the centre height right. I made a shouldered bush for the mandrel nose end to support a 1/2" mandrel and a double ended one, like a stud coupling with no threads, to support the index plunger at the other end.
                      That little lathe was also fitted up with a Cowell screw-cutting kit and a back-gear using gears from a scrap damper actuator. It did a lot of good work for me. All that stuff went when I traded up to a Myford.
                      I sometimes wish that I had kept it for the mantelpiece.
                      DiodeDick
                    Home Forums Materials Topics
