Well for a bit of sound advice from experience.
A few years ago I cut up a copper silver soldered boiler that also had structural sif bronzed joints.
This boiler was made professionally by Tom Goodhand in the very early 1960s for a medium sized 5"g loco that had seen a great deal of use in a hard water area.
The regulator of disc in type type was made of brass. It showed no sign of dezincification. It was 40 plus years old when I cut up the old boiler. It was re-used in the replacement boiler I made. The blowdown valves low down on the backhead showed bad signs of dezincification and the old ones were discarded. The bottom water gauge fitting showed some signs of dezincification, but in any event was replaced with a better design on the new replacement boiler.
My first boiler had a brass silver soldered regulator assembly for the body, and all but one subsequent boilers have had the same.
I remove the brass blowdown valves every 4 years for the hydraulic test. As clearly below the water line they are to a certain extent sacrificial. I give the bodies a life expectancy of 10 years.
Boiler bushes have to be of bronze due to the temperatures that occur when silver soldering boilers that brass would be prone to melt. Also the threads on such bushes, although finished later are far more resilient than that from a brass bush.
I hope this clears up any confusion.
Cheers,
Julian
