If the intent is to uses a C3 size, or thereabouts, lathe indoors, the Chester Craftsman is too large. It is a heavy machine, 300KG, capable of swinging 300mm, (450mm in the removable gap ) and hoilding work 600mm between centres.
The chucks are heavy, especially the 200mm 4 jaw independent.
I have a ETR BL12-24 which is effectively the same machine, (Warco BH600 lookallike ) with a 5MT Spindle and a Norton gearbox. Versatile, but by model engineering standards, a big machine.
Were I in the market for a new lathe, I would seriously consider the SC4. Have only seen one in use, other than the ones at Arc Euro. Apart from having to use changewheels again, it seems to have most of the features that I would want.
HTH
