Posted by gerry madden on 13/12/2022 23:26:57:
Jelly, yes a static deflection measurement is just 'part of the story' but both static and dynamic deflections in a given structure are of course intimately linked. If I could halve the static deflections in my Wabeco mill spindle, I would get two benefits. The first would be achieving a given dimension on a work piece with perhaps fewer passes. The second would be improved surface finish, as a consequence of lower dynamic amplitudes.
Its clear to me that from the magnitudes of the deflections in my mill, the weakness is not the spindle bearings, the spindle flexing or clearances between bearings or housings etc. Its mainly the supporting structure. I'm sure if the manufacturer had done a little bit of FEA work on this he could have optimised where he put the metal and given me a much better machined for the same cost.
Gerry
Fully agree, the spindle assembly is very likely the most rigid element with respect to lateral deflection in the whole assembly, whilst the head-column slideway and column-bed connection are very likely sources of deflection.
I'm pretty sure there's a Stephan Gotteswinter video about trying to eliminate some of the deflection in his old Optimum MB4 mill (which is very similar in design to many of the Wabeco mills) using epoxy to improve the fit and bedding of some parts, which suggests that the inherently compromised design is exacerbated by "good enough" machining of mating surfaces too.
Reducing static deflection would (usually, absent unlucky resonance effects) result in reductions in dynamic deflection too, although I was mentioning it in an attempt to illustrate to Howard that if you were measuring that kind of deflection statically, there was potentially even worse real world deflection at certain cutting speeds which were unfavourable (the same being true of much bigger more heavily built machines as well)
I would be interested to see a comparison of the dynamic deflection in a mill like yours to a more old school milling machine design (which didn't have the benefit of FEA, but does have lots of material to increase stiffness and/or simply absorb and dampen vibration)…
I have a suspicion that the older design would still have dynamic deflection, but simply with the periodicity shifted such that it had less impact on surface finish in the anticipated operating range of RPM/Feeds
Edited By Jelly on 14/12/2022 00:09:54
