Unusual Go-No Go Tool?
Home Forums Workshop Tools and Tooling Unusual Go-No Go Tool?
Viewing 25 posts - 51 through 75 (of 86 total)
  • #559287
    Martin King 2
      @martinking2
      BTW is that a helix on the parallel brass part of the point?
      Martin
      pgk pgk
        @pgkpgk17461
        If you don't like silly stories then don't read this.
        It's 1854, 15 years after Charles Goodyear invented ebonite. The coalition forces are fighting Russia in the Crimea. We're in the T&SD dept of the War Office. Great Grandad Q is briefing Grandpa Bond:
        "This machine can be taken apart and concealed in a mere cabin trunk. To use it you charge up these Leyden jars by rubbing your amber cane across the silk. Once charged you need to be certain that the voltage is accurately calibrated. Place the micrograph controller around the print area and clip the hole upon the stylus tip in it's retracted position. If you only see a spark when the indictator is in the GO position then it's ready. If not then you may have to discharge the jar to the needed level.
        Once adjusted place one of the thin wafers of ivory into the print area and lower the stylus to the writing position. Wind the clockwork spring that controls the on-off contact, set it spinning, switch on and you can now use the pantograph to trace your message in micrography."
        pgk
        #559295
          Posted by Martin King 2 on 21/08/2021 18:30:20:
          Martin
          It’s a scuff mark from the ‘wiper’ contact … pitch matches the screw thread.
            Posted by Martin King 2 on 21/08/2021 18:29:20:
            Just wondering if there are is any small melted pitting on the inside which would support the arc idea? ie sparks?
            I need to investigate this very carefully … not sure how fragile that plastic might be.
            As you can see; the heavy marks are on the area where the plastic sleeve is contacting the ebonite body.
            It will be tricky to look at the interior surface of the ‘window’ areas, but I’ll give it a go.
            Robert Atkinson 2
              @robertatkinson2
              It is almost certainly a breakdown voltage tester. A lower voltage version of this:
              http://www.lasertools.co.uk/Product/5655/Adjustable-Spark-Tester
              But I can't figure out what it was connected to or the scale units.
              Robert G8RPI
              #559314
              Robert Atkinson 2
                @robertatkinson2
                Thinking some more I came to magneto tester, possibly on the primary circuit. I then found this webpage:
                https://www.themagnetoguys.co.uk/test-equipment
                see the wooden handled spark gap abut 1/3 down the page.
                My only other thought was testing the early medical type shock machines. That might explain the odd measurement units.
                Robert G8RPI.
                #559335
                  Posted by Robert Atkinson 2 on 21/08/2021 22:11:13:
                  Robert G8RPI.
                  Thanks, Robert
                  … I think revelation might eventually come if we can ever find any reference to MICROGRAPHS as a unit of measurement.
                  crying 2
                  I know what micrographs are ; and to date, I have failed to find any other use of the word.
                  Jon Lawes
                    @jonlawes51698
                    I tried to dive in deeper to the use of the word Micrograph, and even the earliest use of the term says they are to do with Photographs taken through a microscope or by similar techniques. But in the earliest editions of Merriam Webster it also lists this version which I was unaware of:
                    "an instrument for measuring minute movements by magnifying and recording photographically the corresponding vibrations of a diaphragm moving in unison with the original object"
                    #559455
                      That’s further away from the standard definition than I have ever seen, Jon yes
                      you may be onto something [‘though I’m not exactly sure what]
                      A good working definition for modern usage is that a micrograph is a representation of a microscopical view.
                      We then have a sub-set called photomicrographs, where the medium is photographic.
                      #559475
                        … and on this page, Jon’s new-found definition gets top-billing : **LINK**
                        https://medicine.en-academic.com/32911/micrograph
                        I need to find some details of these instruments
                        and … as if by magic: Nineteen pages from 1911
                        https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2124883/
                         I  now need some coffee !
                        Edited By Michael Gilligan on 23/08/2021 07:42:51
                        #559476
                        pgk pgk
                          @pgkpgk17461
                          #559477
                            My search in Cornell’s library was a little disappointing: **LINK**
                            https://www.cornell.edu/search/?q=micrograph+polygraph#
                              Thanks, pgk
                              If my reading is correct, then Moh’s micrographic surgery simply involves the use of microscope imaging to confirm that the cancerous tissue has been fully excised .. so I don’t think this gets us any further towards understanding the device.
                              If I’ve missed some important point, please do let me know.
                              [quote]
                              Mohs surgery is a precise surgical technique used to treat skin cancer. During Mohs surgery, thin layers of cancer-containing skin are progressively removed and examined until only cancer-free tissue remains. Mohs surgery is also known as Mohs micrographic surgery.
                              #559507
                              Graham Meek
                                @grahammeek88282
                                Hi Michael,
                                I have tried "Micrographs" as a company, as 100 and 300 Micrographs being a unit of measurement. I have tried it as a "Pocket type current setting device", as well as voltage. Putting "vintage" or "antique" into the search does nothing either. The searches assume that one is looking for a device to buy or information about Micrographs, ie pictures.
                                A real enigma this one.
                                Gray,
                                #559509
                                  Pondering if it's a spark voltmeter (electrostatic, not power) I looked up the formula in hope it would match Michael's graph of the instrument's scale.
                                  The formula is:
                                  kV = 3 * air_pressure * spark_length + ¹·³√spark_length
                                  Although it contains an exponent, ¹·³√, I don't believe the formula curve matches the instrument.
                                  And if it's a spark device, I agree with Michael's comment – 'seems like an accident waiting to happen.'
                                  Possibly 'Micrograph' is a reminder, 'this tool belongs with the micrograph', and isn't the name of the tool itself or a tradename. Another meaning of micrograph is an instrument for making small engravings, though I don't see how electrostatics would play a part in that. Some sort of scale reducing Xerox machine maybe?
                                  pgk pgk
                                    @pgkpgk17461
                                    Posted by Michael Gilligan on 23/08/2021 08:51:22:
                                    Thanks, pgk
                                    That was my take on it too but I did wonder whether the actual surgery was just thin skin planing or some other technique since cutting cancerous tissue always risks cells breaking off into circulation It would be possible (not sure if applicable here) to use fine wires to plane and cauterise then again the tissue cells would be too distorted to identify. There is a method of using a radio frequency cutting tool that leads to far less tissue distortion but that is bound to post date your gizmo. Quite fun to use if one got the settings right from destroying an abnormal eyelash hair follicle to slicing through an abdomen.
                                    Link
                                    https://www.medicalexpo.com/prod/ellman-international/product-68342-606351.html
                                    pgk
                                    #559515
                                    pgk pgk
                                      @pgkpgk17461
                                      SOD
                                      .You're starting to sound like great grandad Q..
                                      pgk
                                      #559516
                                      Martin King 2
                                        @martinking2
                                        "A real enigma this one"
                                        Perhaps used for pushing down the keys on a coding machine?………
                                        Hat, Coat etc….cheeky
                                        Martin
                                        #559521
                                        Keith Petley
                                          @keithpetley53472
                                          Michael,
                                          Just thinking out loud here….
                                          …but if Micrographs isn't the maker's name then the device has no maker's info or serial number etc. which suggests that it may have been made 'in-house'. In that case a "graph" could be informal in-house jargon. For example, "100-300 micro grays per hour" is not an outlandish scale.
                                          Keith (who knows nothing about radiation measurements, except what Google just turned up)
                                          #559548
                                          Graham Meek
                                            @grahammeek88282
                                            I have just been looking at Martin's original pictures again.
                                            The lettering looks to have been engraved and the "C" does not look quite right to me, Suspecting it might be a badly formed "G". The wax or white paint filling may have come out of the lettering.
                                            Doing a search for MIGROGRAPH did to my surprise show some results, but again to do with electron microscopes.
                                            I have yet to discover what a MIGROGRAPH is other than a miss typed word, but for there to be 10 pages in the search I cannot believe that there would be many hits for a miss spelling.
                                            Gray,
                                            #559553
                                            pgk pgk
                                              @pgkpgk17461
                                              Promising:
                                              The linked article is dated 1911 and describes a new instrument for detecting minute motions of a diaphragm with applications for physiology and physical science.
                                              Unfortunate that the full article is members/subscription only
                                              I know Michael found similar links but this may be one of the first…
                                              Link
                                              https://jamanetwork.com/journals/jama/article-abstract/438880
                                              pgk
                                              #559554
                                                Posted by Graham Meek on 23/08/2021 17:47:11:
                                                The lettering looks to have been engraved and the "C" does not look quite right to me, Suspecting it might be a badly formed "G". […]
                                                Nice try, Gray … but inspection under the stereomicroscope confirms the letter to be C
                                                  This one's for you, Gray
                                                  [ click ^^^ for larger image ]
                                                  Steviegtr
                                                    @steviegtr
                                                    I'm still thinking old magneto tester. Remove screw cap from spark plug. Insert through square hole & through the small hole. Screw cap back on the plug with H.T cable attached to it. Back off the insert to not go side. Start magneto & slowly screw the shaft in until the plug sparks. Which the H.T would at some point when the brass pointer gets close enough to let the spark jump across it.
                                                    Steve.
                                                    #559586
                                                    duncan webster 1
                                                      @duncanwebster1
                                                      But the pointy thing would be aimed at the ceramic,
