Can anyone identify this engine for me please,
It's a 2 stroke spark ignition single, fairly crude castings and machining so may have been from a casting kit,
There are no fittings for a contact breaker outfit, but has a machined slot in the nose and clearance for a cam and push rod,
Alloy head, cast iron cylinder, approx 3/4" bore & 1" Stroke, overhung crankpin and a bronze connecting rod, the piston looks a bit skewed with the deflector on the crown hand filed, intake on the back of the cylinder with exhaust through slot drilled & filed in the cylinder casting, carb's missing unfortunately,
Total height approx 3.3/4"crankcase back to front of nose approx 3", crankcase approx 1.5/8"
Edited By RJW on 08/03/2018 21:02:32
