Universal Grinding machine construction series?
Home Forums Model Engineer. Universal Grinding machine construction series?
Viewing 25 posts - 126 through 150 (of 152 total)
  • #206301
    David Colwill
      @davidcolwill19261
      Why not have a longish single article describing the machine and its features with a link to a self published book.
      Simple.
      Regards.
      David.
      Michael Checkley
        @michaelcheckley34085
        The build of large traction engines or trains often spans over many issues and can be repetitive from project to project so I`m not sure why this should be a problem for tooling.
        This sounds like an advanced project so maybe the more basic setting up and machining steps could be missed out with only reference to how each feature needs to relate to the other and only the tricky parts detailed for each part?
        For me such a series would be well accepted if the design and description includes the details needed to produce a high precision machine. By this I mean the sizing of parts with material and stiffness considerations e.t.c, dimensional and geometric tolerances, bearing alignments and preloads e.t.c. If this machine is capable of doing precise work then it will be high up on my list of tooling projects.
        The discussion of which mag this goes in to seems obvious to me…
        #206312
        David Clark 13
          @davidclark13
          Hi Harold
          I always allowed 2000 words per page and 8 photos per page. Drawings I allowed 8 per page (individual components) but obviously A4 drawings might take more room. Depending whether they were original components or assembly drawings.
          It does look like the series is too long to publish.
          #206333
          Ian S C
            @iansc
            Definitely too long for MEW, it needs to be done in months, not years.
            Ian S C
            #206336
            pgk pgk
              @pgkpgk17461
              I'm sure these things have been thought of.. depending on the publishers economics. Either a USB flash drive with detail pics and the overview and notes in a serialised form..or even a pull-out supplement for a few issues to give a nice tidy bundle of construct.
              #206339
              John P
                @johnp77052
                Hi there,
                John Mac ,you were spot on with the style of construction even down
                to the thickness of some of the parts.The largest part of the machine
                the base has only 11 basic parts and requires little more than
                cut off bandsaw and a mill /drill to see a basic assembly.In
                some ways designing and building a machine such as this not only
                involves making a working machine but some considerations need to
                be taken into account that it is being made in a model engineers
                workshop enviroment.As this part weighs in as something like 65 kg
                some provision has to be made to be able for instance to be able to
                move this item around and to get it off and on the mill safely.If your workshop
                is anything like mine some times this sort of thing can be a real headache.
                However some provision has been made within the article get over
                these sort of events and many others,its just part of the build.
                Alan, i was close on the number of drawings for your Stepperhead machine
                but suprised that there are only 180 components.I had the opportunity
                to see this wonderful machine of yours in some detail at the 2012 Mex.
                I was on the Smee stand opposite with the cnc cutter grinder.The part
                count on this machine of mine included only parts that had to be machined,
                parts such as nuts, bolts, screws , bearings , springs ,belts and other
                bought in parts were excluded from that count.I know that Mark C had
                queried this earlier. I know from looking at the photo's you would think
                well where are they ,i do the same but nevertheless they are all there.
                Some of these hide in places that can't be seen and have already
                been in MEW and also ME ,on page 9 of MEW 232 is a photo
                of the workhead drive gearbox and in ME 4494 and 4496 the
                hydraulic counterbalance mechanism for the wheelhead.
                To some extent proliferation of short articles will reach a saturation
                point and leave void of new stuff to read ,people who write maybe
                long articles would wary of doing so for fear of them not being
                published.I have already reached this point as another article that i
                was working on, a shorter construction article also like this grinder
                that had not been done before i have abandoned ,the build and
                the drawings will continue but the article is dead.
                Earlier on in this thread Roger Vane had some comments that were
                spot on in the amount of time and effort required to produce a
                lengthy article and are worth re-reading.
                I have spent a very long time on this both the build and the article ,
                at my time of life it is not likely i would wish to spend more time re-writing
                to accommodate a different format however "simple" this may seem .
                The job is done , or very soon will be and the article as it is would have
                to be very much a take or leave it situation.
                Time moves on and i have other things i wish to do.
                  John without giving too much away it would be intertesting to know what machines you had available to make this grinder. If you have say a Bridgeport with long table and a large Colchester that will reduce the number of readers who could take one on if they only have an ML7 and vertical slide.
                  #206345
                    Posted by John Pace on 02/10/2015 11:55:48:
                    I have spent a very long time on this both the build and the article , at my time of life it is not likely i would wish to spend more time re-writing to accommodate a different format however "simple" this may seem . The job is done,, or very soon will be and the article as it is would have to be very much a take or leave it situation.
                    An open question to John and Diane if I may …
                    Would it be practical to publish this 'series' as a set of magazine-size 'specials' ?
                    If there were [say] six issues in the set, then readers could buy the first one, and then choose whether or not they wished to subscribe to the remaining five. Publication could be paper and/or digital [as demonstrated by the MEW 25year special, this seems to be a viable arrangement for MTM to use]
                    The advantages are:
                    1. only those who are seriously interested need purchase the full set
                    2. those 'undecided' would only commit to one issue
                    3. those 'not interested' would not have their magazine padded with 'inappropriate' material.
                    4. the set would be available to anyone [not just subscribers to one magazine]
                    5. the set would build into a contiguous 'book'
                    If this proved successful; I could see it as a model for publication of any 'big' project.
                    David Clark 13
                      @davidclark13
                      The cost of paying the author for this project would be about £8000. This would rule it out for the web or a special
                      #206347
                        I suppose the biggest problem with that Michael is cost. As the specilas would have a limited number of sales the £50 a page would have to be covered by fewer people so the cost of the special would be a lot higher. Also there may not be as many adverts which would counter some of teh production costs.
                        Its a similar situation if part or all were put on the website, would an author be happy to have work on the website that they are unlikely to get paid for? Generally the mag only pays per printed page.
                        J
                        EDIT DC was thinking the same way that I was
                        Edited By JasonB on 02/10/2015 12:46:07
                        #206348
                        John McNamara
                          @johnmcnamara74883
                          Hi John Pace
                          I sent you a Private Message
                          John Mac
                          #206351
                          Harold Hall 1
                            @haroldhall1
                            Thanks David for the information.
                            Now with David's figure of 8 drawings of individual parts per page and with there being 1600 machined components that equates to 200 pages. With there being a few less pages of text (compared to my original estimate) and a few more pages of photographs the total becomes 253 pages. At four pages per issue that becomes 63 issues nearly five years of MEW.
                            If, John, you want to get your efforts into the public domain then creating your own website for it would seem to be the way forward and can be very rewarding personally. There would of course be some cost in having the website hosted, probably around £50 per year.
                            Some have suggested this forum could host the project but it would be very time consuming for the owners to add the pages to the site for which they would get little reward. And then, who would be responsible for receiving the inevitable questions that an article of this magnitude would produce.
                            Harold
                            #206356
                            Mark C
                              @markc
                              Jason B,
                              "would an author be happy to have work on the website that they are unlikely to get paid for?" yes, I would. I don't know about anyone else but if I have something drawn up that might be of use then I am happy to let others use it. I design/build machines for a living but for something involved in my hobby time (also designing and building things, must be a sad person? ) I would simply make it available to others as long as they are not making them for profit. Perhaps that is just me, but it just seems like the right sort of thing to do to me, others may think otherwise.
                              Mark
                              #206390
                                ME has always carried the occasional tool build and while I am sure some readers of MEW might like to see those articles in MEW, that would mean losing other content that might then have not appear at all.
                                One of the distinctions between the two magazines is that ME carries a high proportion of longer series, whereas most series in MEW are two or three parts at most. It's part of the distinct character of the two magazines which do, in fact, have distinct readership profiles.
                                The text and photos for John's article alone would take about a year to publish in MEW, even if we did not include any drawings. I would guess that this could u double if all drawings were published. ME can put articles in alternate issues and still keep things moving but such a series would dominate MEW for a long time.
                                I'm currently working with an author on a series, that if it goes ahead will be six parts, and I must admit I am looking at ways of shortening it or breaking it up into smaller chunks.
                                This is very much about the practicalities of publishing long series, and no reflection on John's work – attentive readers will have seen a number of articles by John during my tenure, and I have more lined up waiting their turn.
                                John Stevenson 1
                                  @johnstevenson1
                                  Whilst this machine and Alan Jacksons Stepperhead machine are very interesting and have some very novel features they are complex which leads on to the next question ?
                                  Would or in Alan's case are, any being built give the range of machines needed, costs and material and cost importantly, time ?
                                  We are at a point in time where, as an example the Polly Models loco's are more than accepted. Something that 10 years ago would ave got you kicked out of a club for arriving with a, heaven's above, kit loco.
                                  Fast forward to today and many tracks even run Polly running days. Whilst surface grinders are not that rare, cylindrical grinders in a home shop are. For a start other than tooling not much is made from hardened material on models but we now have tips that can handle quite hard materials. I have some that will easily handle 65 Rockwell which was the domain of the grinder at one time.
                                  Interesting machine and well worth a few part article to whet someone's appetite but I do question is a build article would ever be followed in metal ?
                                  Edit
                                  Formatting has lost a paragraph and should have questioned after the polly model example whether chequebook engineering and just buy a small machine.
                                  A Myford MG7 can actually be bench mounted and they regularly change hands for sub £500
                                  Edited By John Stevenson on 02/10/2015 20:22:37
                                  #206401
                                  John P
                                    @johnp77052
                                    Jason when i built this machine it was made using the maximum
                                    capacity of the equipment i have .Many of these machines have been
                                    seen in past MEW articles.I have a Warco Mill an A2f which is no longer
                                    sold by Warco .Chester still sells this machine as 830VS-R turret mill.
                                    The machine that i have has been modified ,the table travel has been
                                    increased to nearly 23 inches and a raising block for the head will
                                    see 24 inches from spindle to table ,the machine is part cnc
                                    and manual operation.
                                    A Warco lathe GH 1000 , 6 5/8 inch centre height 40 inch between
                                    centres converted to part cnc . Was an article in MEW from 207 to 212
                                    even had its own forum thread.
                                    Much modified Dore Westbury milling machine converted to
                                    cnc only MEW 179 short descriptive article.
                                    Cnc cutter grinder MEW 143 to 147 construction article,i think you
                                    have seen this machine at MEX 2012 i believe you stopped and spoke
                                    to me on the SMEE stand.
                                    Cut off band saw 4 1/2 inch.
                                    Quorn grinder.
                                    Myford 7 also part cnc operation.
                                    Gear hobbing unit MEW 193 Descriptive article.
                                    A thread milling attachment which is currently with MEW as an
                                    unpublished article.
                                    Several other pieces of home made kit for cutting racks, toothed
                                    belt pullies , adjustable angle plates and the usual workshop
                                    paraphernalia.
                                    All of these have been instrumental in some way in the completion of
                                    the machine.
                                    Hope this helps.
                                    Anonymous
                                      Posted by John Stevenson on 02/10/2015 20:19:33:
                                      My experiments with insert machining of hardened steel on the lathe went well, but I'm still going to hang onto my cylindrical grinder. thumbs up
                                      Blimey the MG7 must have been before the Ark, my cylindrical grinder is late 1960s and even that is a MG12.
                                      #206407
                                      SteveM
                                        @stevem36008
                                        Hello John,
                                        I don't think this has been been suggested as a decent option but it makes sense to me. I guess if it doesn't make sense someone will surely let me know…
                                        Publish in a single article a good overview of the machine. Or just post a thread. Or both. Included would be details of the full article, which you could sell as a pdf to anyone who's prepared to pay whatever you think is reasonable.
                                        The cost of production would be next to nothing – it sounds like all the hard work has been done already. Delivery would be by email with the attachment.
                                        If somebody really wanted it delivered as a hard copy you could offer that option but would cost more.
                                        Sell it for a tenner for the download and I'll make the order just to read the article even though I'm probably never going to build it!
                                        Steve
                                        #206408
                                        Gray62
                                          @gray62
                                          Posted by Andrew Johnston on 02/10/2015 21:52:10:
                                          Crikey, built in the late 60's. that's positively modern, my cylindrical grinder is a Studer type OB, built in 1948 and still able to turn out extremely accurate work, abeit much modified from original due to damage sustained to its original pedestal and motor assembly. The main grinding wheel shaft still runs in its original bronze taper bearings as does the primary workhead. The significant modifications are to the drive system using a dedicated 3 phase motor to run the grinding wheels as opposed to the original belt drive from a common motor which ran the wheel head, table motion and workhead via a series of belts and gearboxes from s single motor in the pedestal.
                                          To add to SteveM suggestion I think that might be the way for John to go, I for one would buy a copy for the interest value and what may be applicable to further enhance my grinder.
                                          Graeme
                                          #206412
                                          Enough!
                                            @enough
                                            Posted by SteveM on 02/10/2015 22:15:50:
                                            Sounds fine in the context of this forum. But imagine it from the point of view of someone who hasn't been party to this discussion. He sees a constructional magazine promising him details of how to build this machine, buys the magazine and then finds that if he actually wants details he has to send money.
                                            Some magazines in the past have taken a similar approach and people have felt a little cheated.
                                            Frankly, I think this discussion simply highlights that it's a bad fit for either magazine. I think a lot more people – both subscribers and non-subscribers – would buy it if it were published separately in book format for a reasonable price (there's the rub). And after the initial rush, book sales might continue for years. Look at the "Workshop Practice" series or (perhaps a better example) the GHT books (like gold dust when they are out of print).
                                            #206413
                                            John Stevenson 1
                                              @johnstevenson1
                                              Book format would be better but comparable to something like building the Bentley aero engine as it all about one subject.
                                              GHT's work is about many subjects and each reader will be attracted by different articles in the book.
                                              Because the book would be a one subject book it would not be as popular and therefore sales would be a lot slower.
                                              #206416
                                                Thanks for the list of tooling John, I don't take MEW so would have missed all the other articles. Presumably quite a few would need to be built first to allow a potential maker of the grinder to have the tooling needed
                                                SteveM I did suggest a build thread earlier on. But a 2-3 part overview in one of the mags would be another option with full details elsewhere. Easy enough to upload it all to Dropbox and sell or give people the link and/or upload it here to a subscriber only section here.
                                                Bandersnatch, if the mag had just the 2-3part overview it would obviously be written and promoted differently so would not be "promising him details of how to build this machine" Lets face it most builds in ME people also buy the drawings for be it Loco, Traction Engine, IC, Steam, etc
                                                #206474
                                                Ajohnw
                                                  @ajohnw51620
                                                  I for one would be unlikely to buy 31 editions of any magazine for a project. I have mixed feelings about more than one really.
                                                  In this case I suspect that the design and build will eventually finish up in a book so often think that it would be better if things started that way but this isn't good for a magazine which needs designs in order to continue to exist. Magazines could also shorten the number of issues needed rather than often containing a lot of bits of some particular projects. I suppose this is needed in order to broaden the range of interests covered in a single issue but maybe some rationalisation would be possible.
                                                  Maybe the answer in this case which would allow a lot more detail to be included is people like these who will publish subjects that come down into the fringe interest category. I found them via a couple of detailed books on some aspects of microscopy. They aren't available from any other source. Conventionally published works on the subjects they cover are very expensive due to the limited audience they are aimed at.
                                                  They appear to publish to order even one at a time but the books arrive pretty quickly and they have been around for some time now. A blog on the web would be sufficient to give an over view of the machine etc. I'd guess the author also gets some payment for their efforts without prices going over the top.
                                                  Edited By John W1 on 03/10/2015 14:27:50
                                                  #206479
                                                  Roderick Jenkins
                                                    @roderickjenkins93242
                                                    It has always seemed to me that one of the major advantages in having a design published in Model Engineer is that drawings are usually added to the MyHobbyStore library and continue to be available long after the author has expired or a book has gone out of print. I recently bought the drawings for one ETW's engines that were first published in the 1930s.
                                                    If the grinder drawings were added to the library and available for purchase, an article or 2 could provide an overview and perhaps some details of any particularly tricky machining procedures. It has hardly likely to be made by a beginner needing step by step instructions.
                                                    Rod
                                                    #206486
                                                    David Clark 13
                                                      @davidclark13
                                                      I don't think anything has been added to the Model Engineer plans for over 20 years.
                                                    Home Forums Model Engineer. Topics
