Universal Grinding machine construction series?
Home Forums Model Engineer. Universal Grinding machine construction series?
Viewing 25 posts - 26 through 50 (of 152 total)
  • #129327
    John Stevenson 1
      @johnstevenson1
      Diane,
      Go for it, it will be well received.
      There are three landmarks in the right of passage for a Model Engineer.
      The first is screwcutting.
      The second is parting off
      And the last one is buying a set of quorn grinder parts.
      Note I said buy as once you have these parts you are then a member of the clan who owns the castings.
      Peter Tucker
        @petertucker86088
        Hi Diane,
        I'm very interested. Pleas put it in MEW so I can read it.
        Peter.
        #129330
        NJH
          @njh
          Yep Diane
          I too would be interested – MEW is surely the right place?
          John you are nearly right and I'm at stage 3 – but with Stent castings! ( I don't need to buy the Quorn too to complete the rite of passage do I?) OK there are lots of other bits too as well as castings – all quite interesting to make and it is a project I have a go at from time to time. It's now about 70% done. Who knows, one day I might even finish it. Cost effective? ……… well you can buy an awful lot of cutters for the cost of the components but then USING the thing 'aint really the main objective!
          Norman
          Edited By NJH on 11/09/2013 19:34:52
          #129333
          donkey
            @donkey
            I am looking forward to it already. Will it start in the next issue lol.
            bri
            #129335
            Sub Mandrel
              @submandrel
              I would be interested, but not inbuilding the complete thing, just getting ideas. I would hope that there is plenty of discussion of whys and wherefores, not just drawings and a few pointers.
              My instinct says that this should be a series for MEW, however, although many of use found Stepperhead interesting and useful, some MEW readers have declared their attention span does not exceed three pages, let alone three issues.
              From a purely sales perspective, it's ongoing series and writers you get to know (and we have sadly lost several due to the march of time over the past decade) that keep interest, as much as good content.
              John Coates
                @johncoates48577
                Sounds great and probably something I would build
                I would expect it in MEW as that is why I subscribed to this in the first place
                Having found that recent a shaper series is in ME has made me think that maybe MEW is not the magazine I thought it would be
                If this goes in ME then I fail to see the future relevance of MEW
                My 2p worth
                Anonymous
                  Posted by John Stevenson on 11/09/2013 19:11:35:
                  Ah well, looks like I'm never going to be a model engineer. sad Screwcutting and parting off are routine, but I'm never going to buy a set of castings for the Quorn, as I've already got a Clarkson T&C grinder. Does having the 'Quorn' book count?
                  #129350
                  Harold Hall 1
                    @haroldhall1
                    There seems to be some considering that MEW is on its way out. I do see a copy of ME every issue but over some 70 years I have only purchased a handful, and then mainly for the advertisments. If MEW did go out of print I certainly would not purchase ME (Sorry Diane you are doing a great job) even if it was split 50 50, modelling/workshop, and I am sure that there are many like me. Perhaps go for Home Shop Machinist, but then probably I am past needing such as my workshop activity is in decline.
                    Harold
                    #129352
                    Harold Hall 1
                      @haroldhall1
                      Perhaps I should have added that I feel there is a misconception on the part of some that most readers of MEW are also model engineers.
                      Unless things have changed, the early surveys showed that less than half had any involvement with model engineering and quite a number of these indicated that other workshop activities, tool making for example, took a larger proportion of their workshop time.
                      Harold
                      #129355
                      Robbo
                        @robbo
                        Posted by Andrew Johnston on 11/09/2013 16:56:53:
                        Posted by CoalBurner on 11/09/2013 16:38:12:
                        Yep, it gets my vote whichever magazine runs it
                        Half in one, half in the other? devil
                        As LBSC might have said, words in one and music in t'other.
                        Would the CNC bit be used for all functions, or is it an option and manual use available.
                        Sounds good, and I already believe that MEW is on the way out.
                        Phil
                        #129359
                        Sub Mandrel
                          @submandrel
                          I claim membership of this elite fraternity!
                          I started making the 'Trent' grinder but stopped when it got to the point where it does all I need, but is clearly not finished, if that make sense?
                          Cutter Holder
                          Table feed and angle adjustment
                          ER22 cutter holder with 12-stop ratchet
                          #129363
                          Martin Cottrell
                            @martincottrell21329
                            Hi Diane,
                            Count me in as interested! I reserve judgment as to whether or not I would build one until reading the preamble to the construction series to assess the features and benefits of the machine. Building aside, I always find well written articles are full of hints and tips that can be applied to other projects.
                            As for which magazine the article should appear in, the obvious assumption would be MEW but as editor of ME I assume that ME is where you propose running the articles. My personal opinion is that interesting articles have been spread too thinly between both magazines over the last 12-18 months to the point where i find myself reading the odd few pages in each magazine then chucking them aside to join the " might but probably wont bother reading later" pile. I would be happy to drop MEW if a few more quality tooling articles were incorporated into ME. I only subscribe to both mags as I'm afraid I might miss something good if I drop one or the other…..long gone are the days when I used to be banging on the newsagents door to get my hands on the next copy of ME on the day of publication, take it home and read cover to cover in one sitting. Sorry for the off topic rant but others have already chucked in their two pennies worth so I thought I'd chuck mine in too!
                            Regards, Martin.
                            #129366
                            Diane Carney
                              @dianecarney30678
                              Many thanks all for your considered responses. i am delighted to see they are, in the main, positive.
                              Regarding which magazine – as editor of Model Engineer my concern is what is best for Model Engineer, which is why I have asked the question here. I was hoping that I would not get a negative response from those who only take Model Engineer for the model making aritcles and would be averse to such an article. Contrary to my expectations, I don't think anyone has expressed that view. Those who only take MEW and who would be interested in this article will perhaps have to think about a solution to that dilema.
                              I should have mentioned that if we run this it will only start in the New Year or Spring of next year. The machine in question is not quite finished. I would propose to run it every other issue and either two or four pages each time so it will certainly not overpower the magazine.
                              Further comments would be welcome but for now, once again, thanks to those who have taken the time to post.
                              Diane
                              #129368
                              NJH
                                @njh
                                Hi Diane
                                How about a bit of warning here when you are about to start the series? I will then review my allegiance !
                                Norman
                                #129371
                                Gone Away
                                  @goneaway
                                  Posted by Diane Carney on 11/09/2013 22:19:58:
                                  At $228 a year for the two paper mags ($142 digital) , it didn't take long thinking about it. I don't think my interest runs that high.
                                  #129373
                                  John Stevenson 1
                                    @johnstevenson1
                                    Posted by Robbo on 11/09/2013 21:05:45:
                                    Phil
                                    Hope someone tells David so he can switch the lights out……….
                                    #129374
                                    Gray62
                                      @gray62
                                      Diane,
                                      How about giving us a 'taster' of what may be to come, maybe a short article giving an overview of the machine and its capabilites, along with maybe a few pictures of the machine as is or a General Assembly drawing.
                                      CB
                                      #129387
                                      Diane Carney
                                        @dianecarney30678
                                        Hi CB
                                        That's a reasonable idea. Maybe once we get our new website template an intro would make a good website article. I'll think on that, thank you.
                                        Diane
                                        #129389
                                        _Paul_
                                          @_paul_
                                          A long drawn out and neccessarily complicated article, might that be better as a stand alone publication rather than eat up valuable Magazine space?
                                          Are you looking to expand readership? as I can imagine it being rather off putting for a new reader picking up the Mag in Smiths and flicking through it only to find many pages of a complicated part article.
                                          Paul
                                          #129395
                                            Diane
                                            Thats because I am too nice to say itwink 2 I subscribe to ME as I like to make models if I was interested in making workshop equipment I would take MEW, if I liked both then I'd subscribe to both.
                                            I can put up with the odd couple of pages that you have introduced recently but would not want to see more.
                                            As for all those that say thay want to see the article yet also say they feel MEW is going down hill would this not be the type of article that could bring it back from the edge rather than more variations on tool height gauges, vice modifications etc?
                                            J
                                            #129396
                                              Following Jason's comments …
                                              I do not make "models" and have therefore never subscribed to ME; although I do have a collection of old issues, purchased at an average of about 10p each. (At which price, of course, they are great value!)
                                              When MEW was launched, I presumed that this would provide the range of articles more relevant to my own interests, and that ME would focus on models.
                                              200+ issues later … it is evident that I was wrong.
                                              jason udall
                                                @jasonudall57142
                                                As I have said previously. Weather I renew my subs to mew is under review. This muddies the water…should I be considering taking me INSTEAD?
                                                (Esp. Since renewing mew seems to be against the flow on the website. …)
                                                Edited By jason udall on 12/09/2013 09:21:59
                                                #129400
                                                Diane Carney
                                                  @dianecarney30678
                                                  Posted by JasonB on 12/09/2013 07:57:27:
                                                  Diane
                                                  J
                                                  A fair enough comment, Jason, and it might be more representative than has come across so far. This is what I am trying to establish. Although I think that if it were to run it would have to be, as I said, every other issue at most, with 'one-off' Workshop Topics in the alternates. Model making is always going to be the primary concern of Model Engineer, don't worry. We also have some first rate model making series on the stocks. It's a struggle to fit it all in these days!
                                                  Diane
                                                  #129411
                                                  Ziggar
                                                    @ziggar
                                                    Diane
                                                    really ?
                                                    then why has DC1 been begging for at least the last year for more articles ? if its that difficult to fit it all in then why cant you let some of the workshop topics you've just mentioned be published in MEW rather than in ME ? MEW is more akin to a trade mag now than a hobbyist mag. Especially when even the Eds special section contains nothing more than blatant adverts.
                                                    looking back through this thread im seeing the majority of answers are saying that MEW is the right place for an article like this. But obviously that doesnt have any bearing on the matter. Its going in ME no matter what anyone says.
                                                    Why not just merge the two mags together now, rather than in the future. Get the uproar and complaints over with now and merge the two as im pretty sure that thats the intent anyway. Gradually introduce workshop/tooling articles into ME [as your doing] so that the change over is hardly noticed in ME land. Then all your left with is just a load of MEW subscribers left out in the open without the mag they paid for.
                                                    Z
                                                    PS. i also think this article should be in MEW…….
                                                    Edited By Ziggar on 12/09/2013 11:40:08
                                                    #129414
                                                    Diane Carney
                                                      @dianecarney30678
                                                      Posted by Ziggar on 12/09/2013 11:39:22:
                                                      Really? You obviously know more than me. Mind you, I'm only the Editor…
                                                      Can I just remind all readers that I am not responsible for MEW and have no say in, or responsibility for, its content. The two are completely independent magazines. The purpose of this thread is to gauge the acceptibility of an article for Model Engineer only.
                                                      Diane
                                                    Home Forums Model Engineer. Topics
