Time isn't missing, Neil, what's wrong is that the equation is for thermal conductance, not conductivity.
Thermal conductance is the heat transfer per unit time, per unit area, per unit temperature, per unit thickness . If you see what I mean!
A.k.a. how much heat (Btu) flows in one hour through one square inch (cross section) of material, one inch thick, with one degree F of temperature difference across it.
IN SI units, Joules/sq.m./degC/m/sec. I think.
Thermal conductivity is a property of the material itself, independant of the structure of the object through which the heat is passing.
Thermal conductance depends on thermal conductivity of the material, but in conjunction with the dimensions of the object through which the heat is passing..
Thermal conductance is the reciprocal of thermal resistance.
Caveat – I'm rusty, having given up heat transfer calculations 3 years ago when I retired, and although I'm bilingual (well, more than that, but I'm not sure that quadlingual is a word – I can (or could) work in fps, cgs, mks, and SI) in most units, I haven't used imperial units for heat transfer in over 40 years! So any errors in the above are down to atrophy of the relevant brain cells!
