understanding timing belt specs.
Home Forums Help and Assistance! (Offered or Wanted) understanding timing belt specs.
  • #617699
    Anthony Knights
      @anthonyknights16741
      I currently have a belt drive on my lathe which uses a timing belt marked 1.5 x 100. The 100 refers to the number of teeth on the belt, but I am unable to match the 1.5 to any dimension relating to the tooth size or pitch. To confuse the issue, all the pulley/belt suppliers I have looked at on the internet specify their products by tooth pitch. Can any body help me to match the 1.5 figure to a tooth pitch so I can order a new pulley. The other alternative is to just order two pulleys and a belt of about the right size and change the lot.
      Thanks in advance Anthony.
      Anthony Knights
        #617700
        bernard towers
          @bernardtowers37738
          try googling toothed belt specs there's a lot of info on there
          #617705
          KWIL
            @kwil
            Looking at your albums, it appears your lathe is a Clarke cl300m, is this correct?
            #617707
              I can’t remember the exact explanation, Anthony … but the strange specification of your belt has something to do with circular pitch.
              There was quite a recent thread here which mentioned it.
              Edited By Michael Gilligan on 18/10/2022 13:09:04
              #617709
                Many of the imported machines use a "module" type pitch so yours is likely to be 1.5 x pi = approx 4.7mm pitch. The chinese web shops may well have them.There is a seller called Ali who will send it Express delivery for a few quidwink
                My X3 for example uses a 2×65 which is 6.3 pitch x 65T
                Edited By JasonB on 18/10/2022 13:12:30
                #617715
                peak4
                  @peak4
                  Posted by JasonB on 18/10/2022 13:09:58:
                  Here you go, this site suggests a 4.71mm pitch, which seems to be 1½ mod
                  https://www.zzr-parts.com/modulus-synchronous-timing-belts/1-5-x-100-teeth-replacement-drive-synchronous-timing-belts/
                  Bill
                  #617722
                    Posted by Michael Gilligan on 18/10/2022 13:08:38:
                    Sorry … I was in a hurry and didn’t express that very well blush
                    What I meant was:
                    the strange specification of your belt has something to do with it not referencing circular pitch
                    Anthony Knights
                      Well thank you people for your contributions. I have now established that the 1.5 figure means a tooth pitch of 4.7mm. I also have links to suppliers of belts with this pitch. I did say in my original post, that I was after some different sized pulleys. I have been back on the internet and cannot find any suppliers of pulleys with this pitch. Plan "B" is to order 2 pulleys + a belt with a 5mm pitch. Plan "C" is to turn a flanged bush to fit the motor spindle and attach an existing pulley I have, after boring it out. I'll try plan "C" first as it will be cheaper.
                      #617838
                        Posted by Anthony Knights on 19/10/2022 09:02:02:
                        I suspect this standard is the Betamax of the toothed-belt world
