Undersize Taps
Undersize Taps
Home Forums Workshop Tools and Tooling Undersize Taps
Viewing 25 posts - 1 through 25 (of 28 total)
  • #16573
    Paul Scholey
      @paulscholey17560
      Paul Scholey
        @paulscholey17560
        I need to tap some 8mm holes in an aluminium engine case that have been welded up for re tapping to fit  the barrel studs. The problem is that the original 8mm holes are  always tapped under size so that the barrel studs are a tight fit. I have a set of standard Goliath taps but they measure 8.12 mm which is much to big for standard studs.  The engine case is for a Lambretta and as this is something I would like to help other people with I would like to be able to use standard studs rather than make thicker ones all the time.
        Just as a matter of interest can anyone tell me  how factory holes are tapped under size and are undersized taps available? I cant find any.
        Thanks in advance for any help.
        Edited By Paul Scholey on 24/08/2010 21:02:41
        #54686
        macmarch
          @macmarch
          Hi Paul,
          If you want the studs to ‘lock’ then use the taper tapt. The studs will then lock themselves in.  I wonder how you are measuring  the M8 taps. I have always repaired  Ali castings with ‘helicoil’ type inserts.
          cheers
          ray
          #54688
          KWIL
            @kwil
            Out of interest, have you done a trial hole in a spare piece of Ali, tapped with your taps, just to see how “loose” they are??
            #54689
            Gone Away
              @goneaway
              Paul, I’ve seen oversized taps around – they’re used on parts that will be plated after tapping for one thing so are not that uncommon – but I can’t say I’ve ever seen undersized taps.
              Commercially/industrially though I’m sure they could be obtained to special order in reasonable quantities. Or a manufacturer with a decent tool room may make them itself …. something you might consider. Should be feasible for tapping aluminum.
              You could also dig out a tap manufacturer (or two) and call them. They would let you know the position and who knows, they might have the odd few kicking around.
              #54694
                You could try a thread forming tap, they push the metal into shape rather than cutting it and should be a little more accurate, just get the tapping drill correct.
                Just tried my M8 taps in a calliper, cheap one comes in at 8.11, better quality spot on at 8.00.
                Have you measured the studs as its likely these are what give the tight fit as its easier to control the size of an external thread than an internal one, are they a cut thread or rolled?
                Jason
                Edited By JasonB on 25/08/2010 08:23:54
                #54697
                Dinosaur Engineer
                  @dinosaurengineer
                  You could try a set of “serial” taps. These are different from normal taps in that the thread forms are progressively larger in diameter from the 1st to the 3rd tap . The 3rd tap being the normal full size thread . I often use the No. 2 tap to give a tighter thread fit on engine studs. The different sizes are denoted by machined or etched rings around the circumference of the shank . 1 ring for number 1 , 2 rings for number 2 and either no ring or 3 rings for number 3.
                  These taps are considerably more expensive than normal taps and are normally only available in sets of 3. the number 1 tap sometimes has a core diameter guide pilot in front of the normal thread cutting form.
                  A coarse thread such as American UNC is often recommended for aluminium as its deeper threads are stronger or as mentioned in previous post, “Helicoils” are much stronger than normal threads especially in Aluminium .
                  Most commercial studs are produced to quite a loose tolerance class . If you can select some larger studs from a batch or make from some long cap head screws this would help. Ideally if you could make your own studs to the maximum metal condition this would give a much tighter fit .
                  #54699
                  Dinosaur Engineer
                    @dinosaurengineer
                    I should have mentioned that “serial” taps were initially made for tapping tough materials. Each tap only removes approx one third of the total material to be removed to make the thread. Also the 3rd tap removes less than the other two and this gives a finishinig cut to give an improved surface finish.
                    #54710
                    WALLACE
                      @wallace
                      I’ve found that the sets of metric taps sold by ARC will cut slightly undersize – the final ‘plug’ one needs to be used otherwise the (commercial) bolts are tight. Others in my motley collection (  Kennedy, Warrior etc) are ok even if using a 1st taper (obviously  the tap is run past the tapered section !).
                      They’re cheap enough so might be worth a try.
                      W.
                      #54712
                      KWIL
                        @kwil
                        It is not unusual to find that the normal, taper, second cut and then plug / bottoming tap each take an additional cut (beyond the taper obviously). As DE says above on the second Serial type is tighter than full thread.
                        It is noted that proper Whitworth threads are far better in aluminium for studs than metric, this is one (!) of the drawbacks of the metric system, being a relatively fine thread system, even the so called coarse range.
                        Edited By KWIL on 25/08/2010 16:46:50
                        #54715
                        Paul Scholey
                          @paulscholey17560
                          Thanks for all your replies. I have tried a trial hole and it is just to slack, I am trying to get the original fit. There is a weak point on the casing on the inside of the stud holes where there is very little material, this is where the cracks develop, so I cant drill it larger to fit Helicoil because it would make that point even weaker. I will look into the Taps that have been suggested.
                          #54716
                          Paul Scholey
                            @paulscholey17560
                            The average size of the studs seem to be  about 7.75mm if they are cut or formed.
                            #54717
                            Dinosaur Engineer
                              @dinosaurengineer
                              Assuming the studs are of a full thread profile then 7.75mm O.D. for an M8 thread means that the studs are at the bottom of a 6g tolerance which is only a medium fit class. If the threads are less truncated than normal threaded components then it is likely they are undersize to a 6g tolerance class. I would have thought that engine studs should be to a better tolerance class than this .On a good thread tolerance I would have expected a full profile O.D. in the order of 7.90 – 7.95 mm. But maybe I’m expecting too much !
                              Edited By Dinosaur Engineer on 25/08/2010 18:56:30
                              Edited By Dinosaur Engineer on 25/08/2010 19:00:12
                              #54720
                              Sub Mandrel
                                @submandrel
                                My HSS metric set M3-12 (£20 at a boot sale!) opens up the thread with each tap. You can use the second tap for a tight fit (almost a force fit) and the plug for a free but close fit. If you use Tubal Cains 60% thread sizes for the drills the taper tap barely cuts a thread and you have to ve very careful about re-engaging so I often start with the second (says Pat*).
                                *I’m 1/4 Irish so I can get away with that
                                #54727
                                Paul Scholey
                                  @paulscholey17560
                                  Do your Taps have a make on them?
                                  #54743
                                  Anonymous
                                    Interesting, I had read somewhere that the bottom tap in a hand set was slightly larger than the taper and 2nd. Can’t find anything about it in Machinerys Handbook though, but my older copies do mention the serial tap sets already discussed. However, for my metric hand tap sets it doesn’t seem to be the case.Commercial screws fit fine in a thread using the taper tap only. I only use the bottom tap if I need a few more threads at the bottom of the hole, and I never use the 2nd tap. All the metric tap sets are by Dormer. It will be interesting to experiment with some of my older BSW/UNC sets to see what happens.
                                    If the tap cuts a bit oversize you can always tighten up the thread a bit by putting a tapered rod in to the hole and hitting it with a hammer. This will distort the top few threads and tighten the fit. Similarly a ball bearing on the top thread and hit with a hammer achieves something similar.
                                    #54753
                                    Gordon W
                                      @gordonw
                                      My twopennoth:- the bottom tap usually cuts bigger, I’m assuming the holes are for head studs and are blind, so will need the bottom tap. Do not try to screw into a taper tapped hole, studs only held by two  (or one) thread, could crack hole. Are the studs genuine spares or maybe copies, and undersize ? I would use alloy epoxy for a simple job, weld up, machine etc. for a proper job.
                                      #54758
                                      Paul Scholey
                                        @paulscholey17560
                                        Thanks for replies again,  all the studs are roughly the same size but they have to be to screw into the casing, full 8mm just wouldn’t screw in. All the threaded holes in the casing for the studs see to be the same size if its a 40 year old engine case or a new one.
                                        Does anyone know who stocks Serial Taps?
                                        #54760
                                        Dinosaur Engineer
                                          @dinosaurengineer
                                          Just checked Arc Euro Trade website details :-
                                          P/No. 060 080 00600 M8 x 1.25   £4 for set ! Tel 0116 269 5693
                                          They do seem very cheap !
                                          #54768
                                          Sub Mandrel
                                            @submandrel
                                            No names on my metric tap sets.
                                            My ancient Machinery’s says that studs should ideally be oversize (not the thread) but in non-critical applications they lock on the thread runout. It also suggests for short runs choosing standard size studs by trial fit!
                                            But why not use stud lock?
                                            Neil W.
                                            #54769
                                            Sub Mandrel
                                              @submandrel
                                              Neil W.
                                              #54780
                                              Dinosaur Engineer
                                                @dinosaurengineer
                                                Loctite was my first thought but I hesitated from suggesting this because of the uknown heat factor. However if the engine is a two stroke with crankcase compression/ transfer then the constant air/fuel mix should keep the crankcase temperature fairly low in which case any of the higher temperature Loctites could be used.
                                                Loctite strength does reduce fairly rapidly with higher temperatures but they do now make higher temperature variants. A Google search on ” Loctite high temperature” should reveal suitable alternatives.
                                                I agree that oversize studs is the better option but the Loctite solution would work if its a  conventional Two stroke.
                                                #54782
                                                Bogstandard
                                                  @bogstandard
                                                  For locking a stud into position, get yourself or grind up a ‘layout’ centre punch (60 deg tip).
                                                  Find the depth the stud screws into the casting, and about 2 or 3 threads down from the top thread, go around the root of the stud thread with the centre punch. You should only need about four equi spaced pops around the one thread core.
                                                  Once tightened in using the double nut technique on the stud top threads, that will quite effectively act as a stud lock to stop it unscrewing.
                                                  Another method is to put strips of bacofoil, about 4, down inside the edges of the tapped hole, then screw in the stud. That should make up enough of the deficiency between the stud and hole size to make it tighter. I have used up to 0.004″ ali shim before now to get real sloppy studs to tighten up. Trim off the sticking up bits with a stanley knife after it is assembled. Drink can material is around that sort of thickness.
                                                  Not a pretty site, but it gets the job done.
                                                  Bogs
                                                  #54793
                                                  Ian S C
                                                    @iansc
                                                    Back when I was overhauling Continental aircraft engines we used over size taps to tap out loose exhaust stud holes to take over size studs, 0.012″ over 1/4″ UNC, over that the thread got drilled out and retapped for a Heli coil insert.Ian S C
                                                    #54796
                                                    Richard Parsons
                                                      @richardparsons61721
                                                      If you cannot get an undersize tap, make an oversize stud. How? Simple if you have the old studs/bolts make two rollers to fit your knurling tool holder. These rollers will have a 60° angle and be hardened to match your metric studs.  Set up the feed to cut the thread and set up your tool in the tool post.  Chuck your stud and run in your tool as though you were knurling. This will up swage the thread oversize.  Take it gently and not put too much pressure on the tool as the thing can be fierce.
                                                      It does the same thing as Bogstandards centre punch but more so
                                                      Dick
