unc / unf to metric
unc / unf to metric
Home Forums Workshop Tools and Tooling unc / unf to metric
  • #76336
    Clive Farrar
      @clivefarrar90441
      I have just bought the set of bottle engine castings from Forrest Classics.
      I knew it was from the USA but it never even crossed my mind about the threads.
      All the screws etc are supplied but I do not think i have the taps to match.
      Not checked my stock yet as I can not get in the gargage.
      So 5-40 3-48 2-56 1-72 uk source of taps at a reasonable prince of convert to metric
      discuss!!!
      Regards Clive
      Clive Farrar
        @clivefarrar90441
        #76337
          This is a little table I made up when working on American designs. For UNC/UNF just choose metric fine or coarse to get the closest to the tpi
          Its not quite complete and the fractions should really be on a separate line but it does for me.
          Tracy tools, tapdie.com should have reasonably priced tools
          Jason
          Edited By JasonB on 15/10/2011 19:18:29
          #76339
            Just tarted it up a bit
            #76345
            JohnF
              @johnf59703
              For good reasonabley priced minature UNF try Brownells.com in the USA they are a gunsmiths supply house–I use them quite a bit.
              In fact I will be placing an order soon so could tag on anything you want if you contact me direct.
              Terryd
                @terryd72465
                Hi Clive,
                I would suggest that if you decide (perhaps for authenticity) to use the original American thread sizes Tracy Tools is about the best bet. Their carbon steel taps are perfectly adequate for most model engineering. Most of Brownells taps appear to be out of stock.
                However I prefer to convert to metric as Jason suggests . Effectively you then only need two sets of taps – metric fine and metric coarse. No messing about with 7 or 8 different thread systems with all the expense and frustration that entails. Since my workshop burnt down claiming most of my tools, I have gone entirely metric and have not regretted it.
                Just an opinion,
                Terry
                #76365
                  The only thing about converting to metric threads is that you are OK with fasteners but if you are threading the ends of rods etc then you need to change the rod Dia, hole it goes through and so on.
                  And there is also the fact Metric nuts and bolt/screw heads are quite flat and look wrong on say a Hit & Miss or steam engine.
                  For both these reasons I prefer to convert to BA. I’ve just machined all the fixings for a 1/2″ scale Domestic stovepipe from hex stock and Metric would look well different and you could not even get the larger dia heads in in some places.
                  J
                  #76381
                  Gone Away
                    @goneaway
                    Apart from the 2-56, those are quite oddball sizes even in North America. You’d be a little pushed taps/dies even here – it would take some digging at least (odd number threads (1, 3, 5 etc are essentially non-preferred).
                    I’d take the advice given – change them to metric. I’d probably even do that from here (Canada) where UN threads are the standard.
                    #76382
                    Gone Away
                      @goneaway
                      BTW, there’s a decent thread substitution table (British/US/Metric) at:
                      #76384
                      Clive Farrar
                        @clivefarrar90441
                        Thanks guys the thread tables are neater than the ones i had found and have been printed off to go in the garage.
                        Unless i have them in my current collection which i doubt then it will be metric as i will only need to source a 1.6 mm. Tracy ?
                        I do have BA but i think they only go down to a 10.
                        Regards Clive
                        #76417
                        David Clark 13
                          @davidclark13
                          Hi there
                          I hyave a series to publish on the bottle engine in ME.
                          regards David
                          Edited By David Clark 1 on 17/10/2011 12:04:07
