Ultrasound hardening of copper
Home Forums General Questions Ultrasound hardening of copper
Viewing 15 posts - 1 through 15 (of 15 total)
  • #27502
    pgk pgk
      @pgkpgk17461
      and improved pickle?
      pgk pgk
        @pgkpgk17461
        Has anyone tried chucking a silver-soldered copper fabrication into a standard ultrasonic cleaner to harden it before a further operation on it? And does it shift flux quicker than just a citric acid pickle?
        pgk
        #484819
        peter smith 5
          @petersmith5
          Machine dro used to sell cleaning fluid to go into ultrasonic cleaners. I used it often when fabricating boiler fittings and fittings in copper and brass. Add citric acid crystals plus a touch of the fluid that the fairies use for the best results. Copper can only be hardened by working it and the silversoldering would have annealedit anyway.
          pete
          #484824
          pgk pgk
            @pgkpgk17461
            As I understand it ultrasonics can be used to harden copper… but whether an 'ordinary' unit would do it was my question….
            If pickle in a cleaner works quicker (as one would expect) then a bonus..
            pgk
            #484833
              210 page PhD thesis, dated 1974
              Sorry, haven’t had time to read it
              http://epubs.surrey.ac.uk/848536/1/10804105.pdf
              … You may want to jump-in at 4.14
              Nigel Graham 2
                @nigelgraham2
                I suspect you'd need rather more than an ordinary ultrasonic cleaning-tank to work-harden copper.
                Adding citric acid … if the detergent is alkaline won't they simply neutralise each other in a haze of precipitated something-citrate?
                Machine-DRO might have stocked ultrasonic cleaners and the detergents, but not now. Instead you need their fellow Allendale Group company, called Allendale Ultrasonics. (allendale ultrasonics. co.uk).
                I have just looked on their inviting site – the only thing that worries me a bit is the rather odd mains voltage quoted, of 220V. Ours is 240V (the EU standard is actually 230V but with a tolerance that allows 240).
                #484844
                pgk pgk
                  @pgkpgk17461
                  MichaelG:
                  That article discusses copper plating in an ultrasonic bath as a ' beter' deposit and comments on hardening and cavitation of the foil electrodes from prolonged use. So it does support the idea but doesnt really answer the practical question here.
                  Nigel Graham
                  I meant using pickle as the ultrasound solution 'in a cleaner' was the machine rather than the solution.
                  Perhaps someone wth an ultrasonic cleaner would care to cut two small strips of copper… anneal them and drop one in an ultrasonic cleaner for say 30 mins (sans pickle) and do a simple bend test on the two samples?
                  pgk
                  #484855
                    Posted by pgk pgk on 10/07/2020 04:49:07:
                    MichaelG:
                    pgk
                    I am well aware of that … which is why I pointed you to 4.14
                    Anonymous
                      Posted by Nigel Graham 2 on 10/07/2020 00:37:01:
                      ……… the rather odd mains voltage quoted, of 220V. Ours is 240V (the EU standard is actually 230V but with a tolerance that allows 240).
                      The European standard is 220VAC, while the UK is 240VAC. All the EU did was "standardise" at 230VAC and widen the tolerances to include both 220VAC and 240VAC. The voltage on my mains monitor is reading 240.2V at the moment.
                      The first time we flew in the French Alps nobody's battery charger worked; except my home made one. We measured the mains at 202VAC.
                      #484863
                      pgk pgk
                        @pgkpgk17461
                        Posted by Michael Gilligan on 10/07/2020 08:21:53
                        T'was 4.14 I read a lot of until it wasn't going anywhere helpful ( a few pages past the high mag images). Typical PHD thesis of the era… volume, volume, volume
                        pgk
                        #484868
                          Posted by pgk pgk on 10/07/2020 09:42:55:
                          pgk
                          dont know Funny, that …
                          What I read in 4.14 was about sample dimensions, depth of immersion, ultrasonic power, and duration [and more] … all packed into less than one page.
                          That, together with the documented results was sufficient to convince me that you would be wasting your time [and that of anyone who steps forward to do a 30 min test for you].
                          secret
                          #484874
                          Anonymous
                            At least mine was nearly 10 years later, although somewhat longer. I had to get permission from the Board of Graduate Studies to exceed the 250 page limit. embarrassed
                            #484890
                            pgk pgk
                              @pgkpgk17461
                              Posted by Michael Gilligan on 10/07/2020 10:06:20:
                              secret
                              4,14 describes the method
                              I'll admit i gave up reading at the section covered in electron micrographs so i missed further down at table XI ? and I'm a novice at uderstanding their ultrasonic power compared to a contemporary machine. Table I still seems to be related to use of electrolysis within the ultarsound bath for grain hardness. Presumably I;m not findgn the table results or 4.14 method itself. Ah! found it table XIX p 88… no bloody wonder!
                              ..shows it works but takes longer than 30 mins….
                              Any clue how those numbers relate to work-hardened copper??
                              pgk
                              #484892
                              pgk pgk
                                @pgkpgk17461
                                Posted by Andrew Johnston on 10/07/2020 11:05:08:
                                I recall helping a mate prepare his thesis circa '68 – a whole bunch of us carefully fixing 'letraset' down to make all the headings, tables and graphs. It's got to be a whole lot easier with computer printers now.
                                pgk
                                #484903
                                  Is pgk's question related to Ultrasonic Impact Treatment? As described on Wikipedia it makes sense, ie a hammer head, maybe consisting of several pins, is vibrated at 200Hz, with an ultrasonic component superimposed on top.
                                  The strength of metal depends on surface condition because even microscopic flaws act as stress raisers. Roughly finished bars break in a tensile testing machine before their highly polished twins. As a souped-up mechanical hammer, UIT improves surfaces by removing flaws caused by corrosion, closing micro-cracks, and smoothing the surface to reduce stress-raisers. It also hardens by mechanically altering the metal's grain structure. I guess this form of ultrasonic hardening is only effective close to the surface, but still very useful.
                                  In contrast ultrasonic cleaners work by pressuring a liquid into the surface of an object, mostly dirt, and then rapidly releasing the pressure causing a vacuum. Anything loose is broken away. It must also have a hardening effect, but my guess is cavitation as the wave reverses causes more damage by digging out soft spots that UIT would seal and harden. Maybe the result is a hard but spongy surface.
                                  If the notion that an Ultrasonic Cleaner digs holes in metal is right, it should be possible to see microscopic damage appear first on the matt side of a piece of Aluminium Cooking Foil, because the other side is highly polished.
                                  I'm not suggesting that ultrasonic cleaning is dangerous to metal! In practice ultrasound cleaning is applied in short bursts and has dirt to work on. Doing significant damage to clean metal would need plenty of power and long exposure. After all, the bowl is made of stainless steel…
