Here are a few pictures about that drive mechanism. I hope it's all clear now.
Most of the parts are printed with my old printers(Prusa i2), only a few are done with my (first) Ulti-Printer. So most of the parts are not high quality parts, sorry for that…
This is my 200×300 Ulti-Printer loaded with a 300mm(1'
PLA reel
The filament is entering the PTFE tubing
PTFE tubing supported by a bracket
..PTFE + PLA going up…
In a curved path entering the XY-carriage
To have a free running PTFE tubing without any friction at all I added 2 small ball bearings in the upper green part of the XY-carriage. The PTFE tubing is almost touching the hobbed pulley and the ball bearing. That hobbed pulley is also selfmade, so I could make it's diameter as small as possible(5.5mm!!) The steppers axis diameter is 5mm.
Detailed view
Don't let it confuse you, this is a view looking down on the XY-carriage from my second printer,(completely printed in black), sorry for that…. You can see(barely) one of the ball bearings(guiding the PTFE) in the circular part.
About that interchangeable hotend system, these are the two electronics parts I needed to solder on the little PCB my pal Guy made for me.
One of these little PCB's are mounted in the XY-carriage itself. At right cabling leaving the carriage
The second PCB is mounted onto the hotend. To be on the save side Guy drew a dual lead for the heater on the PCB. Better save than sorrow.
