UK Supplier for Spring Steel Sheet or similar
Home Forums Materials UK Supplier for Spring Steel Sheet or similar
  • #685619
    Mike Donnerstag
      @mikedonnerstag
      Does anyone know of a supplier in the UK for small sheets of spring steel, approximately 0.007″ or 0.2mm? Or, does anyone know of a similar material that can be bent between the fingers to a consistent radius (for hand sanding), and that returns to nearly flat when tension is released?
      Many thanks,
      bernard towers
        @bernardtowers37738
        What about 316 sheet?
        #685693
        Ian P
          @ianp
          Not sure I understand the purpose. If its a springy material and held curved by finger tension, its not going to have a consistent curve radius.
          Is it some sort of sanding block you are trying to make and how big?
          Ian P
          #685748
          Diogenes
            @diogenes
          Home Forums Materials Topics
