uk acme thread suppler
Home Forums Workshop Tools and Tooling uk acme thread suppler
Viewing 25 posts - 1 through 25 (of 26 total)
  • #596072
    Taris Jewell
      @tarisjewell61133
      hi guys I'm after a strange one. my old Colchester master seems to use a left-hand acme thread 3/4 x 10tpi. and I don't really want to try and make that so I didn't know if anyone in the UK sold some.
      many thanks for any help
      Taris Jewell
        @tarisjewell61133
        #596085
        Hopper
          @hopper
          Moore International and others in the current thread on Boxford leadscrews.
          #596104
          Nigel Graham 2
            @nigelgraham2
            Have you tried HPC Gears? I bought from them when I made a new lead-screw for my Myford ML7.
            (I fitted a second-hand, early-pattern screw-cutting gearbox that needs the screw cutting short to end just inside the wall of the box. Rather than risk an un-useable machine if I made a complete dog's dinner of things or the gearbox failed, and treating the lathe to a new screw anyway, I have kept the original lead-screw and other parts carefully as spare / reversion parts.
            #596128
            Stueeee
              @stueeee
              Might be worth taking a look at this website: **LINK**
              #596141
              Dave Halford
                @davehalford22513
                I think HPC is the only imperial leadscrew stockist in the UK
                #596143
                Hopper
                  @hopper
                  ABSSAC UK mentioned in the other thread list them.
                  Surprisingly they quote a maximum accuracy error of 6 thou per foot for their precision screws. Makes all the arguing over metric thread approximation change gears on forums rather moot then.
                  #596190
                  Dave Halford
                    @davehalford22513
                    Please put a link on, all I see in the catalogue is metric.
                    #596191
                    Nigel Graham 2
                      @nigelgraham2
                      Try this one:
                      http://www.hpcgears.com/n/products/linear_motion/leadscrews/leadscrews.php
                      It is they I used, but note that "standard range" might not include your specific choice, and having it made probably won't be cheap.
                      #596405
                      old mart
                        @oldmart
                        Stueee's link to Kingston engineering shows their data sheet 3, but unfortunately their easily available ACME 10 tpi is only 1/2" not the op's 3/4". The 3/4 x 8 ACME is available in rod and nuts, a possibility if the dial graduations could be changed. There are a great many more suppliers over in the USA, but unless you know somebody living there it can be difficult and expensive to ship things to the UK.
                        #596407
                        Nigel Graham 2
                          @nigelgraham2
                          That's exactly what I bought from the HPC catalogue: 3/4 X 8 tpi LH ACME…
                          You don't need import it!.
                          #596410
                          Nigel Graham 2
                            @nigelgraham2
                            OOOps, I beg your pardon. I misread the notification. You want 10TPI. Not the 8 I needed.
                            I've looked it up again:
                            http://www.hpcgears.com/pdf_c33/2.8-2.9.pdf,
                            and no, the only listed 10TPI thread is 0.5" dia.
                            So back to Old Mart's question of whether you can change the handwheel dial, perhaps make a graduated ring to fit over the existing one?
                            #596414
                            Taris Jewell
                              @tarisjewell61133
                              hi, thanks for all replies I've emailed a few different people and it seems £250 is the best price which is more than I'm willing to pay. I'm interested to know some more about changing the handwheels if anyone can recommend a thread or a supplier of good metric hand wheels then I can use any thread I want. i would probably use a metric trapezoidal lead screw if possible.
                              now failing that I am planning on making the lead screw myself as I see no reason to why I can't and I should save £200 and learn a new skill
                              #596415
                              Weary
                                @weary
                                I know that you wanted a UK supplier, however, a forum member on MECH sourced an acme screw-thread (albeit different to your requirement) from Roton Products in the US and had very good service from them. So ,maybe worth considering?
                                Here is Roton Products info' , & Here is the relevant MECH thread.
                                Kingston Engineering in the UK got a mention as a good supplier in the UK in that MECH thread.  Don't know if you have tried them, so here is their site.
                                Edited By Weary on 29/04/2022 21:04:38
                                #596416
                                  Posted by Hopper on 28/04/2022 11:09:14:
                                  dont know
                                  Surely any serious argument is about approximations much worse than that ^^^
                                    Actually … that’s rather a disappointing spec. from ABSSAC UK
                                    Go Compare : **LINK**
                                    https://www.helixlinear.com/blog/acme-screws/what-puts-the-precision-in-precision-acme-lead-screws/
                                    Taris Jewell
                                      @tarisjewell61133
                                      michael it was abssac that quoted me £250 they don't stock them they can just custom make it ill email some more people over the weekend and see
                                      #596422
                                        Posted by Taris Jewell on 29/04/2022 22:27:11:
                                        That makes Hopper’s quoted spec. all the more disappointing, Taris !
                                        … I wonder how much Helix charge
                                        Hopper
                                          @hopper
                                          Posted by Michael Gilligan on 29/04/2022 21:19:51:
                                          dont know
                                          Martin Cleeve's book Screwcutting on the Lathe lists compound gearing with standard set of change gears to cut metric threads on an 8 tpi leadscrew lathe with errors ranging from 1 in 3000 down to 1 in 8000 and that never seems to be good enough for some model engineers who insist on 127 tooth gears etc. But even 1 in 3000 is only 4 thou per foot. 1 in 8000 is thou and 'arf.
                                          #596424
                                          Hopper
                                            @hopper
                                            And when you think of it, even 6 thou per foot is not much total error. That's plus or minus a quarter of a thou per inch. Pretty good for a mass produced item. You'd have to go to an expensive ground thread to fo much better.
                                            Edited By Hopper on 30/04/2022 00:55:43
                                            #596429
                                            Kiwi Bloke
                                              @kiwibloke62605
                                              It's good to see that Halifax Rack & Screw are still going, and now also have a branch in USA. Don't know whether they will still talk to Joe Public, but they were friendly a couple of decades ago… Good luck.
                                              Hopper
                                                @hopper
                                                Posted by Dave Halford on 28/04/2022 14:30:01:
                                                Now that you ask, I can't find it either. Must have got it mixed up with one of the others. Sorry.
                                                #596440
                                                  Posted by Hopper on 29/04/2022 23:56:24:
                                                  dont know
                                                  Martin Cleeve's book Screwcutting on the Lathe lists compound gearing with standard set of change gears to cut metric threads on an 8 tpi leadscrew lathe with errors ranging from 1 in 3000 down to 1 in 8000 and that never seems to be good enough for some model engineers who insist on 127 tooth gears […]
                                                  Yes, I think we are in agreement there … and I have emboldened a few words in the hope of clarifying that
                                                  I do have an ‘purist’ preference for the use of 127 … as, of course, did Martin Cleeve
                                                  its inclusion brings simplicity and convenience [if you can make space to fit it]
                                                  Edit: __ See the images of his lathe that I have previously posted in tribute:
                                                  https://www.model-engineer.co.uk/forums/postings.asp?th=104724
                                                  Edited By Michael Gilligan on 30/04/2022 06:40:13
                                                  #596441
                                                  Hopper
                                                    @hopper
                                                    Whatever. I am not going to get into nitpicking over highlighted words. It's a casual social forum not a PhD thesis. (Although I hear tell PhD's are thicker on the ground than we would have suspected. )
                                                    #596442
                                                      Then let’s skip the clarification and just repeat my main response:
