Don't know how it can sense this
As well as the ABS sensor wheel speed arrangement that JH described above, there are also battery operated pressure sensors built in to the fill valves. These look the same as normal unsensed fill valves from the outside. The batteries on these sensors are non-replaceable, so when they eventually die a complete replacement sensor must be fitted and "coded in" to the car system.
On my last car (which had a sensor based system for TP monitoring) I had a spare set of wheels with winter tyres fitted that didn't have the sensors – replacement sensors are not cheap & must be "coded in" when changed, so I didn't bother. When I swapped over to these wheels, it took about 4 miles for the pressure warning light to come on, which stayed on unitl about 4 miles after I refitted the sensored wheels. No idea about how long the batteries last – that car was over 6 years old when I changed it, though about a year of that was with the winter tyres fitted. Given the 4 mile lag between loosing (or regaining) the sensors, I guess that the sensors only have to respond to an occasional request from the car systems for their status & that the normal battery drain is very low..
My wife's current car displays the actual pressures for each wheel on the car display, so easy to see which one is low. This system appears to trigger at a 3 PSI difference from the setting on the door pillar & activated the first time when the ambient temperature dropped below freezing.
Nigel B.
(edit for spelling)
Edited By mgnbuk on 13/05/2022 11:53:54
Edited By mgnbuk on 13/05/2022 11:54:10
