Type of builds on this site
Home Forums Website Questions, Comments, and Suggestions Type of builds on this site
Viewing 25 posts - 1 through 25 (of 35 total)
  • #383677
    mal webber
      @malwebber91786
      Just a quick question, is ok on this site to start a build thread on a ww1 model artillery .
      Thanks mal.
      mal webber
        @malwebber91786
        ww1 artillery build
        #383685
        I.M. OUTAHERE
          @i-m-outahere
          Can't see why not although there can be no guarantees as t the amount of interest from other forum users but this is the same for pretty much all build threads , maybe post a preview to show what you intend to build ? Are you intending to build this from your own drawings or a set of plans that you have purchased ? Either way you may also want to look at doing a write up for M.E for the model and MEW custom tooling and fixtures you may have had to make .
          #383688
            OK with me
            #383696
            Brian H
              @brianh50089
              I'd be very interested to read about making a model, and the tooling to make certain parts. What sort of piece are you thinking of?
              #383700
              Ron Laden
                @ronladen17547
                Its all model engineering Mal plus its good to see subjects that are a bit different, go for it.
                #383704
                Stuart Bridger
                  @stuartbridger82290
                  Excellent, I for one will follow with interest
                  #383712
                  Vic
                    @vic
                    Interesting project. I look forward to seeing it.
                    #383713
                    Jim Nic
                      @jimnic
                      I would welcome an artillery build log. Although artillery is not my thing I am always interested in how others approach modelling problems and engineered models of any subject are interesting to me.
                      Jim
                      #383715
                      Mick B1
                        @mickb1
                        I too would be very interested.
                        There's an example, at Churchill's hose at Chartwell – a very detailed model of a WW1 'Male' tank 6-pounder installation. I just wish there were a source for the plans.
                        #383719
                        not done it yet
                          @notdoneityet
                          I don’t make models, but the ways that machinining problems are overcome (or not) interests me. The more solutions to a holding or cutting problem, that may arise in the future, the easier the task of getting it done effectively.
                          #383757
                            Fire away!
                            John Rudd
                              @johnrudd16576
                              Posted by Neil Wyatt on 04/12/2018 13:23:28:
                              Fire away!
                              '…..incoming, take cover….'
                              I'll get me coat..cheeky
                              #383875
                              mal webber
                                @malwebber91786
                                Tanks for the feedback , what I had in mind or started to have ago building is the Vickers BL 8inch Howitzer mark vi of 1917 ,no build drawings as such only pictures and a operators manual that has some useful drawings on it , sort of trying to build this in a 2 inch scale [so it goes with the minnie steam engine that I have not finished yet ] anyway reason for asking is that there are not many build logs covering this sort of thing ,I new nothing about a cannon month or so ago but the more i read into it, the more i wan't to have a go building a model of one
                                Thanks Mal.
                                #383882
                                mal webber
                                  @malwebber91786
                                  Posted by mal webber on 04/12/2018 23:43:10:
                                  Tanks for the feedback , what I had in mind or started to have ago building is the Vickers BL 8inch Howitzer mark vi of 1917 ,no build drawings as such only pictures and a operators manual that has some useful drawings on it , sort of trying to build this in a 2 inch scale [so it goes with the minnie steam engine that I have not finished yet ] anyway reason for asking is that there are not many build logs covering this sort of thing and a lot of the build will be metal fabrication work. I new nothing about a cannon month or so ago but the more i read into it, the more i wan't to have a go building a model of one
                                  Thanks Mal.
                                  #383885
                                  duncan webster 1
                                    @duncanwebster1
                                    Why not write it up for ME or MEW. Then you get some dosh (a very poor hourly rate if my contributions are anything to go by), and possibly a wider audience
                                    #383892
                                      Mal, if you put 8" Howitzer into the search box on the home page you will find a few threads about one that was on the site a few years back.
                                      #383897
                                      mal webber
                                        @malwebber91786
                                        Just tried with no result?
                                        #383898
                                          here, here and here for starters and if you look back through Bob Gould's posts there are more plus photos in his album
                                          #383899
                                          mal webber
                                            @malwebber91786
                                            Thanks Jason
                                            #383900
                                              Posted by mal webber on 05/12/2018 08:24:05:
                                              Mal
                                              Please read Jason's instruction carefully
                                              There is a search box on the home page of this site
                                              https://www.model-engineer.co.uk
                                              … which will produce this:
                                              https://www.google.com/search?q=8%22+Howitzer&sitesearch=model-engineer.co.uk
                                              Edit: Jason has, predictably, beaten me to the actual links; but I hope that's useful for future reference..
                                              Edited By Michael Gilligan on 05/12/2018 08:34:51
                                              Edited By Michael Gilligan on 05/12/2018 08:37:07
                                              #383901
                                                Michael, even the usually poor forum search threw up two results which must be a firstwink
                                                Mal, will you be painting up teh Minnie like this model Fowler?
                                                #383902
                                                  surprise
                                                  #383905
                                                  Ron Laden
                                                    @ronladen17547
                                                    I do like the Fowler modelled in a military finish, I think that looks really excellent.
                                                    Interesting how the gun has traction engine type wheels, I guess in those days if large wheels were needed for heavy equipment that was the way to go.
                                                    #383908
                                                    Mick B1
                                                      @mickb1
                                                      Oh gawd! All those rivets! All that drilling!
                                                      I think, if I ever get round to it, I'll try something like a 6- or 17-pounder from WW2 instead… blush
