two stroke on gas
two stroke on gas
Home Forums I/C Engines two stroke on gas
  • #258345
    paul Longley 1
      @paullongley1
      Hi there,​ just read Graham Astburys reply on running a two stroke engine on gas, whilst he's right on the simple two stroke engine, re oil supply, I'd like to add that a large number of two stroke stationary engines ( Petter, Kromhout, etc ) added fuel to the air in the transfer port so avoiding fuel contamination of the crankcase. This is VERY handy, given the risk of crankcase explosion. Most of these engines have a mechanical oiler, as Graham mentioned. Hope this is useful info, regards Paul
      paul Longley 1
        @paullongley1
        reply for James Wells
        #258364
        not done it yet
          @notdoneityet
          Of course, one can run a diesel on gas (with a minimal injection for ignition) GM made an awful lot of two stroke diesels and none of them passed fuel through the crankcase. Not actually heard of them being run on gas, but lots of Lister diesels have been. Perhaps not simple enough? But certainly avoids blowing up the crankcase.
          If they were properly designed to run on gas, presumably there should be a bursting disc incorporated for safety?
          #258365
            Model two strokes can have oil added to the carb rather than just mixed into the liquid fuel so don't see why that should not work on gas as the oil is drawn in by the fuel/air mixture, much like this one I made earlier, oil fed from tank or pump, needle to adjust flow, sight glass to make sure its working.
            #258367
            duncan webster 1
              @duncanwebster1
              I think you'll find that 2 stroke diesels didn't use crankcse induction, they used mechanical blowers to transfer the air into the cylinder, typically the Napier Deltic or the Commer TS3 **LINK**
              They could therefore have conventional pumped oil systems for the crankshaft lubrication.
              Edited By duncan webster on 28/09/2016 20:27:05
              #258373
              paul Longley 1
                @paullongley1
                The ​Petter, and Kromhout two strokes I'm thinking of aren't diesels. They're hot bulb engines, sometimes called surface ignition, or true spark ignition, as in the Petter little pet, universal, m type, etc. The spark ignition types have a jet in the transfer port, the distance from jet to piston is fairly critical. They use a butterfly or shutter inside the transfer port to control airflow ( to a degree ) The hot bulb types have full airflow, but inject fuel into the bulb ( vaporiser ) at the moment induction starts. The fuel then has time to vaporise, ignition being started by the fresh air charge entering the bulb. As has already been stated, most of the diesels use scavenging pumps, a few such as the Petter Harmonic or the Field Marshall use crankcase scavenging with a virtually constant loss mechanical oiler. But, to return to the point, admitting gas through a jet in the transfer port should be successful. Possibly a shutter in the transfer port to help the mixture proportions. With the shutter at low flow, the air pressure in the crankcase wouldn't get to high, it acts as a rebound cushion for the piston. Minimal air is taken in through the reed valves when the transfer shutter is closed.
                #258374
                Muzzer
                  @muzzer
                  Slightly different situation but for interest, modern dual fuel commercial engines used in buses and coaches typically have an additional spark ignition system for when running on natural gas. So they operate as either diesel or SI.
                  #258384
                  not done it yet
                    @notdoneityet
                    Never say never, Duncan. Most two stroke diesels (like the GM's) used a rootes type blower, or similar, for scavenging and forced induction, but the prodigious Field Marshall 'Pop-Pop' single cylinder two stroke diesel tractor had a total loss lube system and worked with crank case compression for air induction. They were in use for some considerable period of time, although the drivers were likely well 'vibrated' after only a short driving spell.
                    We digress from simple two stroke petrol engines, but diesels do run nicely on 'gas oil', after all! International TD crawlers also had engines which were started on gasoline (spark ignition), then changed over, to compression ignition mode, to run on diesel.
                    #258390
                    duncan webster 1
                      @duncanwebster1
                      I stand corrected. Not too long ago I saw a chap passing through my home town on a Field Marshall, Placard stated he was doing Land's End to John O Groats. All I can say is he must have been a glutton for punishment
                      #258407
                      Brian G
                        @briang
                        Does anybody remember Norton's "Wulf" stepped piston twin? This separated the oily bits from the fuel-air by using a stepped piston with the lower annular portion acting as a compressor for the other cylinder. If I remember rightly fuel lubricated the smaller piston rings, so it might not be suitable for a gas fueled engine without some form of cylinder injection.
                        #258410
                        Gordon W
                          @gordonw
                          Can anyone tell me where to find the original query ? From J Wells ? I"ve searched the last few days worth with no luck. Interesting topic, do remember the stepped piston, didn't an east european company do a similar idea? Fuchs or jawa,or similar ? The old brain is going.
                          #258411
                            Postbag 4541 and the reply refered to in the opening post is in postbage 4544
                            #258416
                            Gordon W
                              @gordonw
                              Forgive my stupidity– please where do I find postbag4541 & postbage 4544. ? I've been using this site for a few years and never come across it.
                              #258430
                                Postbag is the letters page in Model Engineer magazine, the numbers are the issues that the letters appear in. The series about internal combustion by Graham Astbury was also in the mag over many issues.
                                #258454
                                Gordon W
                                  @gordonw
                                  Thank you, I thought it might be some part of the dark web, that lesser mortals don't have access to. Suppose I'll have to look for some old copies.
                                  #258456
                                  Tim Stevens
                                    @timstevens64731
                                    Anyone who has difficulty with the above comments might find it helpful to know that there are two systems of two-stroke engine in common use. The Day Cycle used for motorcycle, lawnmower, chainsaw, model aeroplanes, draws the mixture into the crankcase and so, has to provide oil for the big-end, piston etc along with that supply. This can be by mixture or a separate feed or feeds. The other, Clerk Cycle, for bigger, mainly diesel engines, uses a separate pump to supply the mixture to the transfer ports, so the big end etc can be lubricated like a four stroke.
                                    There were much earlier stepped piston designs than the Norton Wolf engine – Dunelt in the UK (Coventry?) and DKW in Germany – both pre WWII. DKW also had success with motorcycles on the Clerk principle, one of which had two sparking plugs, five pistons, and a resonant exhaust system in about 1935. It was so loud that on a good day you could hear the TT from England.
                                    Regards, Tim
                                    #258462
                                      Posted by Gordon W on 29/09/2016 11:11:13:
                                      In Model Engineer Issues 4541 & 4544, so you either need the back issues or a digital sub from HERE which also gives you access to the digital archive.
                                      Muzzer
                                        @muzzer
                                        Back in the 90s, an Australian company (Orbital Corporation) was convinced that they were about to sell their 2-stroke technology to mainstream automotive OEMs including Ford. They kept the air-fuel mixture separate from the lubrication system by injecting it directly into the cylinder at high pressure. It seems to have failed on emissions and they then refocused on using similar technology to achieve stratified charge combustion in 4-stroke engines.
                                        In the event, stratified charge / gasoline direct injection / lean burn etc was successfully championed by Mitsubishi, Toyota, Ford, VAG themselves. Orbital still seems to be in business although these days it is apparently supplying engines for UAVs. There have been loads of weird engine concepts coming out of the Antipodes, almost as many as out of Russia. Must be something in their psyche….
                                        #258480
                                        paul Longley 1
                                          @paullongley1
                                          The s​tepped piston two stroke engine goes back I think to the first war era in some of the submarine diesels. I think the recurring problem was reciprocating weight, most early sub diesels appear to have used dedicated compressor cylinders. I remember seeing on tv years ago, Norton were using their Wankel rotary engines in UAVs as well as their motorbikes to help justify production machine costs. Could be the same firm mentioned above. The company Jenbacher Werke of Tirroll, specialise in gas burning diesels, I found out by accident when researching my 1956 Jenbach diesel ( only a single cylinder type) but again I'm digressing 😵
                                          #258876
                                          paul Longley 1
                                            @paullongley1
                                            Another t​bought occours to me, the successful running of a two stroke engine on gas will depend on the type of gas. The free piston engines made at the end of the 19th century had little in the way of lubrication , they relied heavily upon the lubricating qualities of manmade town gas. Quite a bit of heavy vapour in it. I think there are quotes of having to strip and clean up some parts to return the engine to full power. The slide valves were a problem for some. So, a gas laden with lubricant may not be such an impossible option.
                                            #259219
                                            Howard Lewis
                                              @howardlewis46836
                                              The GM two stroke diesels were uniflow engines, where air entered the cylinder through ports in the liner, and the exhaust left via the poppet valve in the cylinder head. I think that the Foden two strokes may have been similar.
                                              The Roots blower was purely to provide "blow down" for scavenging, rather than supercharging.
                                              The Commer TS3, Napier Deltic, and Rolls Royce K Range engines, and possibly the larger Leyland engine (intended to power a Tank) by having opposed pistons operating in the bore, used one piston to control Inlet , and the other to control Exhaust. timings
                                              Since the induction air did not pass through the crankcase, and specific powers were higher, a separate lubrication system was used.
                                              The Rolls Royce C Range, and Perkins engines, that ran on gaseous fuels were not diesels, they were four strokes and used spark ignition. Most of the components below cylinder head level, other than pistons and rings, were common with the compression ignition parent.
                                              SAAB two stroke petrols used a separate lub oil supply system, I believe, which allowed higher powers.
                                              The Trojan and Sachs two strokes used a piston in a connected cylinder to provide scavenge air, (as did the Perkins Duplex – a two stroke diesel which never went into production). Quite a few two stroke diesels, used stepped pistons to provide scavenge air, but these were usually low speed units use for marine propuslion.
                                              I can see no reason why, for low specific outputs, oil could not be admitted into the Induction tract under the Throttle for a Gas engine. (basically that is what the loop scavenge two stroke does by adding oil to the petrol).
                                              #259244
                                              Clive Hartland
                                                @clivehartland94829
                                                The GM 2 stroke diesels I worked on were double supercharged, with an Exhaust turbine feeding the Rootes blower> I think 24lb pressure was quoted. As said, air was pushed through the cylinder ports at bdc and exhaust was done by 4 valves. Injectors were cam operated and had rack operation to open and close, I had one run away and had to kick off an umbilical fuel connection. The rack operating rod cut into the palm of my hand.
                                                As to the Saab two strokes the later one had three carburreters, one for each cylinder and I saw on Carlson rally car it peaked at 9000 rpm. I am not sure how they injected the oil into the engine but it must have gone through the crankcase. Thereby stands a tale, balked by Bhoringers Merc. stuck in the mud, Carlson jumped out and rolled the Saab over and righted it and drove on. That Kenya Safari was won by a local Volvo, an old one.
                                                My Saab was a normal 3 cyl. single carb.The second one had a V4 Ford engine It really went fast.
                                                Edited By Clive Hartland on 04/10/2016 20:56:32
                                              Home Forums I/C Engines Topics
