Posted by Ian Phillips on 06/08/2014 09:58:33:
Paul
Its not a subject I know much about but its very impressive!
Out of interest, how is the speed measured/certified?
Do you have any form of control once its released (radio or maybe a device on-board)?
Presumably the tether is responsible for sapping a lot of the potential speed? How much faster might it go if untethered?
Ian P
Speed used to be measured with 3 separate stop watches and the average time over 5 laps of 100 metres taken now we have an electronic timing system.
The engine is flat out with no control and fuel runs out before the water.
Keeping the weight to the allowed limit (16lb dry) can be difficult otherwise there are various electronic aids I would like to have fitted.
I have just stripped it all down to repair some fire damage on that second 117 mph run caused by an experiment with an air-scoop that backfired.
The various dry lubricants have been successful in the engine considering its total distance run on one attempt was 31 100 metre laps conventional oils are lost through the exhaust ports as the piston is a slipper type.
Looking at some stills of K9 128mph runs the boat aerodynamics are about right for maximum speed i.e. front sponsons clear of the water and only the propeller in the water it is very close to flipping.
Next month will be another testing time so have to get the thinking cap on to try to go faster.
On some of the ex Soviet ponds they have a hole in the middle to dispose of the central backwash it's nearly level with the water surface.
Paul
Edited By Windy on 06/08/2014 12:39:08
