If your HF ballasts screw up your radio it suggests you should have bought them from a more reputable outlet. It's illegal to sell stuff that doesn't meet the EMC requirements (look at EN55011). Are you using Chinesium crap?
You will also note that despite what you say, the colour temperature is usually specified for fluorescent tubes.
And as mentioned on various previous occasions, LED lights are generally about the same as fluorescent lights in terms of efficiency.
The of the key benefits of HF ballasts is that they turn on almost instantaneously and can coax a little more life out of the tubes before they give up the ghost. As a tube gets older, the voltage rises until it can't be kept running.
For me, one key benefit of LED lights in the workshop is the lack of glass tubes above head height. Belting one of those or dropping one when changing it on top of a ladder could be pretty messy.
Some HF ballasts (and many LED drivers) have very little inherent energy storage, so although it's true that they switch at several kHz, they often have a significant 100Hz component.
Murray
