Michael, as part of a plan to make a model of the church clock which I wind twice each week, I have been documenting the clock. You can see my original posting with a couple of pictures at
A Tower Clock project | Model Engineer (model-engineer.co.uk)
Although this is a Pinwheel escapement rather than gravity arm if it is of use, the details of the clock gearing are
Time train Teeth Rotation
Great wheel Teeth 120 180 Rotates every 3 hours
1st Pinion Pins 10
2nd Wheel Teeth 90 15 Rotates in 15 Minutes
2nd Pinion Pins 8
Escape Wheel Pins 35 2.29 period secs
Escape wheel rotates 80.00 Seconds
3150.00 BPH
Pendulum Length 1.30 Metres
Drive Wheel for Minutes 40 60 Rotates once per hour
Bevel Gear on Minute 45
Chime train
Great Wheel 240 Rotates once per 2 Hours
1st Pinion 10
2nd Wheel 120
2nd Fly Pinion 10
Strike train
Great Wheel 240 One rev = 12 strikes
1st Pinion 20 One rev per strike
2nd Wheel 120
2nd (Fly) Pinion 10 12 revs/strike?
Count wheel 78
I have a spreadsheet that computes the pendulum length from the gear counts in the time chain.
Fiddling with it suggest that if you used these numbers and reduced the number of pins in the escape wheel to 32, then
Escape Wheel Pins 32 2.50 period secs
Escape wheel rotates in 80.00 Seconds
2880 BPH
Pendulum Length 1.55 Metres
which is about 61" effective length – so possibly OK for your pendulum.
In a posting on the other thread Michael pointed me to https://richard.burtons.org/2014/11/28/restoring-a-j-smith-and-sons-derby-turret-clock/ which is a restoration of a very similar Smiths of Derby clock, but that one does have a gravity escapement.
Hope this is of use.
Edited By Peter Cook 6 on 03/12/2021 14:50:43
