turning tungsten
turning tungsten
Home Forums Materials turning tungsten
  • #29521
    Matts BitsNBobs
      @mattsbitsnbobs
      Matts BitsNBobs
        @mattsbitsnbobs
        Hi all,
        As it says, any tips on speeds, tools-HSS or tip tools, lubricant etc.
        A friend has asked me to turn a piece of bar apx 2in down, not got the sizes yet and I was hoping for a bit of advice. I will be using a super 7 if this helps for speed etc, any help would be much appreciated.
        Regards Matthew
        #157532
        Oompa Lumpa
          @oompalumpa34302
          Frankly, sounds like you are in for a real treat. Oh, and he is no friend either.
          graham.
          #157536
          Bob Brown 1
            @bobbrown1
            Try this **LINK**
            #157537
            JohnF
              @johnf59703
              Hi Matt, I turned some down to make some sample counter weights, it is tough but not so hard. I used a tipped tool but HSS will also cut it, the components I made had a 6m thread as well and the tap was a standard HSS tap but it was tough going. Lube well with a good quality cutting oil and you should be OK.
              Many years ago the company I worked for made a lot of counter weights for aircraft and the material was called heavy alloy, it was largely tungsten , not sure of the other components but again there was no particular problem machining these with normal tooling.
              regards John
              Edited By JohnF on 10/07/2014 18:32:55
              #157548
              Bubble
                @bubble
                Hi Matt
                I used to help a friend out, turning tungsten alloy for darts bodies. I don't recall any problems, used HSS and including screwcutting the thread for the flights, probably 2 BA
                Jim
                #157550
                Rik Shaw
                  @rikshaw
                  Hello Mathew – many years ago a dart playing enthusiast asked me to "thin" down the body of a set of tungsten darts. It was probably the easiest material I have ever turned – like butter with a HSS tool bit. Weirdest thing though is that the swarf came of looking golden – like bronze – but within seconds, oxidised and went grey.
                  Rik
                  #157562
                  Roderick Jenkins
                    @roderickjenkins93242
                    Matt,
                    Depends whether it is pure or one of the "alloys". I use the quotation marks because the heavy metal (as used in darts) is actually tungsten powder in a matrix of nickel and iron or copper and not a true alloy. Tungsten heavy metal turns like free cutting steel.
                    Pure tungsten is a different matter. This link may help.
                    If it's the latter – good luck!
                    Rod
                    #157570
                    Matts BitsNBobs
                      @mattsbitsnbobs
                      Thanks everyone,
                      First I will see if I can talk him out of it, if not I will let you know how I get on.
                      Many thanks Matthew
                      #157733
                      Steve Withnell
                        @stevewithnell34426
                        Thanks for the explanation Rod – I've a piece of pure Tungsten bar, 1/4 inch diameter and my experience isn't of something that cuts like butter using HSS tooling!
                        Steve
                        #157743
                        Roderick Jenkins
                          You're very welcome. If anybody has a source of heavy metal bar in small quantities I'd be glad to know of it. It's very good for balancing model i.c. engine crankshafts. 1/4", 6mm, 3/8" or 8mm would all be useful.
                          cheers,
                          Rod
                          Edited By Roderick Jenkins on 12/07/2014 21:28:29
                          #158167
                          Matts BitsNBobs
                            @mattsbitsnbobs
                            Thanks again for all the help, just to let you know I talked him into using brass, but I am still keen to give the tungsten ago at some point just out of curiosity, if I do I will let you all know how bad it was.
                            Regards Matt
                            #158188
                            Versaboss
                              @versaboss
                              Posted by Roderick Jenkins on 12/07/2014 21:28:13:
                              Rod,
                              that's not too difficult. Over the big water they indulge in a strange sport called Pinewood Derby racing. This has developed into a hi-tech affair, and so they use Tungsten rods and balls to put as much weight as allowed into these cars. Search for Pinewood, and you will see it all.
                              I also bought some small off cuts of Tungsten in 4-6 mm dia. (iirc) on this famous 4-letter auction site.
                              I did not any turning tests with these, but if someone asks…
                              Regards, HansR.
                            Home Forums Materials Topics
