Turning Question: Fine Chatter / Wave Pattern
Home Forums General Questions Turning Question: Fine Chatter / Wave Pattern
Viewing 25 posts - 1 through 25 (of 40 total)
  • #700143
    Nigel Graham 2
      @nigelgraham2
      [Cited in my “What I did Today” item.]
      When I turned my steam-wagon’s two connecting-rod shanks, I noticed a curious banding on one.
      The connecting-rods have long, slender shanks tapering from about 3/4 down to 1/2″ diameter over about 5″ , turned from 1-1/2″ dia steel bar (grade not known, possibly not leaded but it still cuts nicely).
      So I used the set-over tailstock method, and on the Harrison L5 lathe; so making a smallish part on a hefty machine with lots of bearing surface and inertia, and nice low feed; with 3ph motor and VFD.
      The banding is a very slight alternation between near-polish and very slightly coarser finish, using a 6mm diameter button insert. It does change slightly towards what was the tail end, held on a revolving-centre; and I noticed the cutting was much better going towards the tail than the headstock.
      Our club had a show-and-tell evening last week so I asked other members what might have caused the banding.
      One suggestion was it matches the lead-screw of 1/4″ lead, but the feed on the L5 is from a separate shaft, not the lead-screw. Another possibility was the saddle “walking” slightly as it moves, actually yawing, due to tiny rotational play; but over that length I would expect the pattern to vary as the saddle moves across areas of different degrees of wear.
      Now, to drive the rods, they had two 1/4″ BSF tapped holes in the embryo big-end; since cut short as I have changed the design. So I screwed a short stud in one, to pushed by one jaw of the 3-jaw chuck holding a temporary soft-centre – a point turned on a length of m.s. bar.
      SO: two other possible causes of the banding:
      1) – The L5’s long feed still has the rack and hand-wheel pinion engaged. Was this oscillating the saddle by a tiny bit, probably <<0.001″ amplitude?
      Be a bit ham-fisted lifting the control lever into engagement, you lift the saddle enough to tip the tool forwards, potentially spoiling the work. So take that nice and softly. This shows the saddle is not immune to being lifted as it travels.
      I also set the cut just as the hand-wheel starts to rotate, both easing the cut start and ensuring the correct feed direction. (What do you mean, ‘how do I know?’ !).
      2) – Is it a function of the way the lathe was driving the rod round? Since the rod was between the spindle centre and a tail centre offset about 1/8″ some 9 inches away, the driving-stud in the big-end was not parallel to the chuck jaw.
      In this situation, does the work try to oscillate as it rotates, perhaps enough to create this strange chatter?
      Any other possibilities?
      Now, in this case the effect is purely aesthetic, not very noticeable and the finished engine is enclosed anyway. So it is not important here; but it may be significant on something else.
      bernard towers
        @bernardtowers37738
        It might be the 6 mm dia button tool, it’s obviously sharper on the right hand side. Have you tried a tool with a smaller (1mm) radius, it will put less load through your workpiece?
        #700219
        Nealeb
          @nealeb
          I have seen what I think is a similar effect sometimes, somewhat random and not regularly spaced. So, probably not down to something cyclically related to a lathe artefact and I have wondered if it is due to a tiny build-up of swarf or other cutting residue between the tool and work. Or maybe something related to resonance in the work and where the tool is with respect to vibration nodes/anti-nodes – never managed to get to the bottom of it.
          #700224
            Try a RCGT insert rather than a RCMT as it will tend to cut rather than push the slender work away from the tool, better still just use the button insert at the ends where you want a fillet and a smaller tip radius **GT tool for the main taper.
            Other causes can be head bearings needing adjustment or a slightly tight gear in the drive train that only meets with another every so often.
            #700272
              Perhaps the most common cause is the tool, job, tool-post and whole machine vibrating during the cut.   Metal is elastic, and a proportion of the energy put into a cut will feed resonances in the same way a bow excites a violin string.   The effect can cause such violent chatter and loud screeching that the operator is forced to intervene.   The cure is usually increased rigidity – reducing tool and job overhangs, and adding centre support, and steadies.   Less violent vibrations have much less obvious consequences.  They include poor finish and banding, both due to the cutter failing to cut evenly, causing the tool, job and machine to vibrate.
              Fixing small vibrations is more subtle, with many options:
              • Adjusting the cutting rate to reduce vibration.  Cutting rate has three variables: feed-rate, depth of cut, and RPM, and can change during the job.  For example banding often occurs when facing off because surface speed depends on diameter, falling to zero at the centre.
              • Matching the cutter to the material being cut.  Even more variables: sharpness, rake and relief angles, cutter dimensions and how it’s fixed to the tool-post.   Carbon steel, HSS, carbide, and ceramics all have pros and cons, and come in different grades.   Hobbyists often do well with imprecisely home-ground HSS, not worrying much about exact angles, but this isn’t good enough for production work, and probably causes vibration problems.   Ditto carbide inserts: these are accurately made to optimise cutting, often within a narrow operating range.  The risk in a hobby workshop is that inserts are used outside their optimised range, with disappointing results.   More confusion because blunt tools often have a polishing action, and get good finish by accident.
              • Making sure swarf doesn’t go back under the cutter
              • Applying suitable lubrication, which varies by material.   Cast-iron, Aluminium. Brass  and Mild-steel are all different.
              • Keeping the cutter at the optimum temperature.  This is another complicated variation based on material, mass, cutter type and shape.
              Hard to pin down exactly which of these many variations are causing trouble.
              And of course, vibration becomes worse if the gibs are loose, bearings worn, motor lumpy, gears mis-meshed, dodgy clutch, lead-screw bent, belt set, wobbly stand or floor, or other mechanical faults.  Light lathes are more bother than heavy ones.
              These problems test operator skill.   Compensating for them explains why experienced operators get good results out of tools in poor condition, whilst beginners struggle with wonderful kit.  Over the years I’ve certainly developed a feel for what my Chinese lathe likes and dislikes in the way of cutters, speeds etc.   Neither it or I are brilliant, and I still get into trouble!
              Phil P
                @philp
                I have a Harrison L5A and had the same problem, I tried everything to reslove it, all to no avail.
                Then I looked at the headstock bearings a bit more critically, the cyclic marks on the work did not seem to correspond to anything that could be measured, but I was suspicious of the front taper roller bearing.
                Once I replaced all the bearings the problem was solved, it turned out that the cyclic marks on the work corresponded with the front roller bearing “cage” rotation. This goes round at a slower RPM than the spindle and it took a bit of finding. It must have had a tight spot that was transmitting through the spindle an onto the work.
                Phil
                #700326
                Howard Lewis
                  @howardlewis46836
                  I had cases of a shaft being brinelled by needle rollers.
                  Worn bearings might well account for patterning on the work.
                  The normal advice to reduce chatter is to reduce the cutting speed, but when using a tangential tool on aluminium, this does not not have a great effect (The tool holder is already hard back against the toolpost, with minimal toolbit standout), but strangely, despite the high frequency noise, the finish seems to be good.
                  The fact that you are turning something relatively long and slender will not help, because it will flex.
                  jason’s advice to use a ground tip rather than moulded may very well help, since the sharp edge will reduce cutting forces compared to the slightly rounded edge of the moulded tip.
                  Again, maybe reducing the epth of cut might help, because of the lower forces.
                  Hope that you get it sorted.
                  #700656
                  Nigel Graham 2
                    @nigelgraham2
                    Thankyou – an interesting range of possible causes, and of course there may be more than one!
                    Bernard –
                    I’m not sure why “of course” a button tool is sharper on its right-hand side when it was new to this operation and I was sometimes cutting both ways with it.
                    The connecting-rod’s small end was on the tailstock-centre and there the 6mm button was about right for the blend radius. At the other end, with a much bigger fillet, I roughed it out with a button tool but finished it with an HSS radius-tool free-hand ground to approx 1/4″ radius.
                    Dave, and others –
                    Vibration… I did notice a curious change of behaviour approaching the small end, and this appeared to be partly from some sort of resonance, though likely combined with the rapidly-changing geometry between the tool and the slender part of the work.
                    There was some signs of “bouncing” at times when trying to take a cut <0.005″ deep, but most cuts were from 0.005 to 0.010″ deep. I didn’t risk heavier than that.
                    A point I don’t think I made earlier is that although the rods are made from the same stock bar, the finish is distinctly different between them, but I could not pin this down. It could be from tool wear.
                    The lathe’s bearings –
                    Well, this is an old machine that may have had a fairly hard life. There is a slight step between the flat surfaces of the bed, up onto the corresponding parts of the gap-filler; but generally it does not seem too badly worn. I don’t know its origin for certain, but I think came from a Gas Board maintenance workshop so was probably not used on long-term production-work.
                    It may have suffered worse when used occasionally but fairly heavily by several of us, including me, in the workshop we used for a small school-club miniature-railway. When that project had to close, we dispersed equipment not earmarked for another railway elsewhere, and the lathe came to me. (None was school property. We had all donated or loaned all the tools and machines including this lathe ourselves, and practically everything was very “pre-loved”.)
                    When I installed it at home I was shocked to find no oil in the all-geared headstock. The moving parts were all heavily oily but more by luck than judgement. So if the headstock bearings are worn or out of adjustment it’s not really surprising.
                    My first action was to buy a lathes.co facsimile manual for the machine.
                    The second was to replace the old, massive 1ph motor with a Newton-Tesla 3ph motor and electronics….
                    Third? Give the headstock a drink!
                    To my delight the previously horribly noisy machine now runs very quietly for its size. (The old motor having been bolted to the cabinet had probably contributed generously to the racket.) Saliently, the headstock does not sound unduly noisy. I tend to run the machine at fairly modest speeds, though with the speed-control knob up in the green sector on the label, but the headstock does emit an odd ticking noise I need track down.
                    So I think some of your posts above point to my giving the headstock a good looking-over.
                    I am not sure as I write if the spindle bearings are adjustable, but I will investigate that. Obviously cutting away from the headstock will unload the bearings, possibly just enough to let the spindle, hence work-piece, to float axially.
                    Though to be fair to the lathe, I must also consider possible play in the set-up, including within the elderly live-centre in the tailstock.
                    Lots of possibilities to investigate!
                    #700663
                    Fulmen
                      @fulmen
                      Lots of possibilities indeed. Chatter is hard to pin down and even harder to weed out. The first line of defense is extra support. Tool stickout, tail support, steady rest, everything adds up. Sometimes a random change in feeds&speeds solves everything (or so I’m told).
                      Maybe I’m missing something, but a button tool sounds like the worst choice for this sort of work. You want to keep the x-axis forces to a minimum, so keep the nose radius as small as possible. And if everything else fails something like a lead mallet can be used to dampen vibrations.
                      #700709
                      Nigel Graham 2
                        @nigelgraham2
                        I think that combination or accumulation of causes very likely.
                        I did try other tools including one of those lozenge-shaped inserts with a 55º tip, but I don’t think it made much difference.
                        Since I was using cuts <0.010″ deep on a small diameter on a heavy machine I didn’t think the force from a new button tool would normally be significant but it may well be on a slender work-piece. Cutting rightwards gave a better finish though still with the banding, hinting perhaps at the effect of bearing play or saddle wear.
                        Wear might include on the rack and pinion teeth as they are used for the power-feed, as the drive-shaft is geared to the hand-wheel shaft. I wonder if uneven wear or damage on the hand-wheel drive-gear or rack-pinion, or swarf trapped in it, might give the racoon-tail effect. This might be enhanced by the rack teeth being more worn on the leftwards-cutting flanks.
                        The more irregular finish I see much more frequently is probably from general, unevenly distributed wear and tear. I will though examine the saddle to see if it can yaw despite being guided on Vee-ways as that could give the regular pattern.
                        Speeds and feeds – The spindle speed did not seem to affect it much.  I was using a very fine feed, not as fine as is possible with the change-wheels and 3-speed feed gearbox, but still probably <0.003″ / rev. I’d need examine the wheels I used, and consult the manual, to be able to calculate the actual feed.
                        The 3-speed gearbox, with a 1:1 central ratio, reduces the overall feed a bit but not much, only 1.25 or 1.5 :1 if I recall correctly. As it drives the lead-screw as well it may be more useful when trying to cut some awkward screw-pitch.
                        I still don’t discount the way I had mounted the connecting-rod though. It was driven between-centres at a slight angle to the lathe’s axis, and by a chuck jaw pushing a stud screwed into the big-end.
                        I don’t know if this arrangement might give some peculiar effects if the drive is rigid. When using a set-over tail-stock does the work need swing back and forth with each rotation? A normal cranked drive dog typically has quite a bit of play in the catch plate or a faceplate slot; a straight dog pushed by a cylindrical pin as on the Myford lathes would allow considerably more oscillation than needed. This stud-driven set-up might have cramped any such swinging.
                        On the other hand, the banding’s pattern is far coarser than I’d expect from this source. Each revolution equates to only a couple of though of tool travel.
                        So I think the first ports of call are dirt trapped in gear teeth, and general wear and tear. These would affect using any type and size of tool on any metal, but the pattern I saw was quite unlike the much more common, irregular “bouncing” finish.
                        #700850
                        Nigel Graham 2
                          @nigelgraham2
                          This is strange.
                          Yesterday I hit the same problem of logging-failing, but noticed the “Log-in” is somehow linked to the home page “Forums” [sic] buttons.
                          There should be only one, and I wonder if having at least four is part of the trouble. What possessed the designer to add so many? Pressing any forum tab would immediately turn “Logged in” to Logged out”. At other times, you can be logged in but moving from the first to last page of a forum would log you out.
                          Just now though I opened the site from the bookmark, and I was not only already logged in but could come straight here!
                          Anyway I gave the lathe a close inspection yesterday. I don’t think it’s as badly worn as I’d feared despite it looking very scruffy.
                          I could detect no play in the spindle.
                          There was some very slight movement on the saddle if I wrestled with it, and the retaining-strip that runs below the rear shear was slightly loose. I removed, cleaned and refitted it.
                          However, the feed rack and pinion are visibly, badly worn. These are permanently engaged and used both for manual and power feed, although they idle when screw-cutting.
                          I did though learn something new! There is a neutral setting on the saddle’s sliding / surfacing selector. (I am familiar with the one on the headstock forward/reverse gear.)
                          The other factors people have mentioned – tool selection (and setting!), speeds, feeds, direction of feed, resonance in the slender work-piece, etc. – may be there. Resonances give definite changes with length; but I think overall those factors more likely to produce an irregular finish than alternating matt and glossy bands.
                          My conclusion is that the main culprit in producing regular bands on the surface finish is that worn rack and pinion.
                          Cure? Well, the only real cure is a new rack and pinion but whether I can justify it, is another matter. Just turning the rack end-for-end might help a little but could bring problems of its own.
                          #700857
                            On the old forum, I once mentioned the use of ‘ball-ended centres’ … [you might the thread if you search hard enough], and several expedient alternatives were mentioned by those practiced in the art.
                            Graham Meek
                              @grahammeek88282
                              MichaelG has hit the nail on the head. When using set-over centres the standard cone centre is only bearing on one side of the 60 degree cone in the work. In extreme cases this can be just point contact.
                              For my part I would use a HSS tool for the finishing cut.
                              Gray,
                              #700915
                              Nigel Graham 2
                                @nigelgraham2
                                Thankyou Michael, Gray –
                                I did notice that although my rods are of “mild”-steel they might be less “mild” than the oddment I used for the soft centre, because the latter ended up with a step worn on it. Better that, than harming the work.
                                I’d not expected that wear to happen. The idea of a soft centre turned in-situ was a blend of accuracy and the difficulty mounting a proper centre. The spindle nose has been damaged by some numpty in the past putting a rough step inside it, probably by careless use of a boring-tool.
                                Still, this was my first attempt at this form of taper-turning!
                                I’ve often obtained better results with an HSS tool than carbide; even on good-quality material. That’s not a fault of carbide tooling per se; and I have not found it needs terrifying spindle speeds as many think, but the inserts are made for narrow ranges of materials and cutting conditions, and we might not always have quite the right combination.
                                Especially for we whose Goods Inwards Quality Control is, umm, variable. I salvaged some former cable-drum tie-rods. This “any old iron” will give fair results with HSS where fine surfaces are not functionally necessary, or the parts will be painted, but a carbide tool simply tears it to bits.
                                #700945
                                Graham Meek
                                  @grahammeek88282
                                  The wear on your soft centre is the indicator of one or more contact points. Of course while this wear is taking place the original “between centres” adjustment that you made when you started turning will become loose. Hence the chatter.
                                  The waviness is probably a product of the of the chatter and the single point drive. Driving the work at an angle, there are bound to be cyclic variations as the work rotates from the single drive source. The work really needs to be driven by a constant velocity joint.
                                  In the past I have made ball or spherical centres from ball bearings pressed into a closely fitting hole. An old drill shank is a useful source for making such a centre for the tailstock. This can be drilled and reamed in situ.
                                  Gray,
                                  #700953
                                  Howard Lewis
                                    @howardlewis46836
                                    At leasr two, of us have made and used ball ended centres for taper turning.
                                    See MEW 322, December 2022.
                                    Such things may well improve the support for the work.
                                    You could try using a HSS tool, with a small radius onn the tip, rather than carbide.
                                    A large radius on the tool tends to encourage chatter. Certainly, a button type carbide tip may well do so, since:
                                    There is an enlarged length of the cutting edge, increasing curtting forces.
                                    Moulded carbide tips are not sharp, in the sense that we normally expect. Ground carbide tips are more likely to meet our expectation of being sharp.
                                    Generally, carbide tips are intended to remove metal fast, (Generating heat to soften the material locally) so shallow cuts might tend not cut all the time, waiting for pressure to build up to the point where the tip does cut, intermittently.)
                                    You are machining a comparatively slender workpiece, which may tend to vibrate, like a tuning fork, and so contribute to chatter.
                                    As already said, the problem may result from a combination of causes, slender workpiece, large radius on tool, wear on the machine. Individually, a it may not cause a problem, but combine several and  the problems combine.
                                    #700994
                                    Nigel Graham 2
                                      @nigelgraham2
                                      I can see now I’d made things hard for myself by a near-rigid drive, but the pattern occurred on one of the rods, not both; and anyway wouldn’t the eccentricity affect each revolution, not a span of many? Unless it was setting up a longer-wavelength resonance.
                                      The wear on the centre was a small step and appeared to be concentric, not concentrated on one “side”.
                                      I do now recollect a diagram showing the principle of a ball-centre, somewhere. It’s probably in at least one of my assorted workshop reference books…..
                                      As you say though, a combination of causes!
                                      #701054
                                      Graham Meek
                                        @grahammeek88282
                                        The point contact would be rotating and therefore would mark the centre all the way round.
                                        The drive is not constant as the work is at an angle and the point contact is dynamic. The point that was nearest the headstock at the front of the lathe would be further away from the headstock after 180 degrees of rotation. The point that was at the rear is now nearer the headstock and so on. This assumes the tailstock is nearer the operator. If it is the other way the same thing occurs but it is a mirror image. It will however give the same marking on the centre.
                                        The single point drive will also give different angular velocities as the work rotates, due to the set over angle. It is akin to a Whitworth quick return mechanism.
                                        Gray,
                                        #701183
                                        Nigel Graham 2
                                          @nigelgraham2
                                          Thankyou Graham.
                                          That shows what I could not determine: the work does oscillate.
                                          I did move the tailstock forwards, towards me, by about an 1/8″ . I used a drill-shank between the tool and work as a gauge: not good enough for a precision-fit taper but fine for aesthetic and lightening functions.
                                          I know if you put a universal-joint in a shaft it needs a matching one at the other end, in the same alignment, for constant velocity.
                                          Clearly I’ll have to do some further reading before attempting this technique again!
                                          #701240
                                          Fulmen
                                            @fulmen
                                            Yes, the work will oscillate, from the chucks point of view the tail stock is moving in a circle around the chucks axis. But as you have pointed out it matches the rotation of the part so it shouldn’t cause banding.
                                            You should be able to make a ball center by placing a bearing ball between two center drilled parts.
                                            #701348
                                            Nigel Graham 2
                                              @nigelgraham2
                                              I see. I take it though the drive-dog also needs rock easily, perhaps by a smooth edge acting on a cylindrical pin.
                                              #701362
                                              bernard towers
                                                @bernardtowers37738
                                                You could also use a bell centre drill
                                                #701373
                                                Fulmen
                                                  @fulmen
                                                  Sure, that might help. But I think you’re chasing the wrong rabbit there.The banding points towards something in the feed mechanism, probably in concert with a sub-optimal setup. And since it only appeared on one part a solution should be available with limited effort. I would do a couple of tests with a sharper cutter before doing anything extreme like cleaning the machine  🙂
                                                  Don’t forget to play with the center pressure, and check the feed/lead screw for runout. An idiot with a lifting strop can do real damage to those.
                                                  BTW, I recently turned a couple similar tapers. Except that they were from 6 to 3mm over a length of 75mm. In 316SS. That’s a flimsy setup if I ever saw one. I managed just fine, and I’m no machining genius.
                                                  #701379
                                                  Nigel Graham 2
                                                    @nigelgraham2
                                                    Thankyou Fulmen.
                                                    Yes- quite a few people have suggested a finer and sharper cutter.
                                                    I did keep watch on the centre pressure. It did ease very slightly at times, probably from the soft centre creeping back in the chuck, or the tailstock clamp not quite up tight enough.
                                                    I don’t think there’s anything wrong with the lead-screw (not used on this operation anyway) and feed-shaft; but the rack and pinion are badly worn and if the pinion has worn unevenly, or had swarf jammed in it, it could well produce a varying feed. It is difficult to examine closely as it is deep inside the saddle, but just visible by shining a light into the gloomy recesses.
                                                    The rack and pinion would be very difficult to replace. I do have a collection of Harrison L5 spares (courtesy of a private seller on this forum) and I will have a look, but I don’t think they include a rack, and probably not the pinion either.
                                                    Where a fine and accurate feed is needed, I’ve not investigated if it can be gained from the 1/4″ pitch lead-screw. The machine’s designers intend it for screw-cutting only, so a fine feed may not possible with the standard change-wheels.
                                                    #701545
                                                    Fulmen
                                                      @fulmen
                                                      If the banding matches the pitch of the rack it’s probably part of the problem. I don’t think it’s about uneven feed but about changes in the rigidity of the system. Are your way gibs tight? Any pinching between rack and drive gear will force the apron into the ways.
