Wolfie, my way is to use a coolant and a tool with a slight top rake angle, I cannot tell you how much but re-grind till you get a good cut. Then keep that tool for the next lot of bronze work.
The tool should have a very small radius on the cutting edge.
When turning Phosphor Bronze it gets hot and the chips come off hot so take care.
Drilling, again take care as it will grip and bind so you need to grind off a bit of the cutting edge flat on both lips.
Only drill in small steps, backing out and clearing regularly.
Reaming, take care as it will grab and you will not get the reamer out unless you knock it out so only allow a very small amount for reaming to size.
Boring, rough turn, clearing chips and swarf as you go and then a fine cut for finishing.
Speeds, fairly fast for the outside but slower for drilling and boring and dead slow for reaming.
No doubt someone will have a different set of ideas.
