Here's my take on machining aluminium. It can be summed up like this:
1050 – pure aluminium, absolutely horrible, worse than copper, might as well try chewing gum
All the aluminium alloys I've machined (2014, 5083, 6063, 6082, 7075) were straightforward
For specific operations this is what I do:
Turning: I turn dry, with a special light alloy insert from Greenwood Tools. I run the lathe as fast as it, or the workpiece will allow, with a least a 4 thou/rev feedrate. I rarely get problems with built-up-edges on the insert. HSS also works well, provided the tool has a decent rake angle, is sharp and is smooth (I use diamond hones after grinding). The main issue is making sure the swarf doesn't end up as a birds nest.
Manual Drilling: No problem with HSS drills, I use WD40 to stop clogging of the drill flutes
Manual Milling: I don't do much of this, but when needed I do it dry. I have had a few issues with HSS cutters getting swarf build up in the flutes, so for preference I use carbide cutters
CNC Milling: Flood coolant (Biokool14 from Hallet Oils), mainly to get rid of chips with both HSS rippa and uncoated carbide mills. I run cutters fast, for example a 6mm carbide slot drill will run at 4000rpm
Best Regards,
PS: Bazyle – I know I've quoted various specification numbers, but then again I very rarely buy metal from ME suppliers, because you haven't got a clue what you're getting. I prefer to use commercial metal stockists.
