Turning and boring almost any* shape. *within reason
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Turning and boring almost any* shape. *within reason
  • #15305
    sam sokolik
      @samsokolik60334
      sam sokolik
        @samsokolik60334
        Some more fun with cnc…
        #502831
          Clever stuff, Sam yes
          Keep sharing your adventure
          DC31k
            @dc31k
            A couple of questions:
            Right now, it is effectively converting a closed shape into a series of (X, A) coordinate values, where I guess the A- increment can be arbitrarily small.
            How easy would it be to make it turn 90 degrees and produce (Z, A) values? I am thinking of a face cam, as used in Brierley and Rush drill grinders.
            https://rushmachinery.com/products/drill-and-tool-grinders/model-132c/
            Second, does it have any built-in idiot-proofing? If I sent it a circular hole with a keyway cut out, would it tell me to go away and pound sand due to the discontinuity in the profile? As a corollary to this, what is the most acute internal angle with which it is comfortable (e.g. an equilateral triangle-shaped bore)?
            Thanks.
            #502872
            Nigel Graham 2
              @nigelgraham2
              I'm not an expert on CNC machining but I don't think the keyhole would be a problem unless the corner radii are very critical . Rather, won't the minima on milling internal dimensions including angles, be controlled by practical machining criteria like the diameter and lengths of the cutters, more than the tool paths?
              I recall seeing a drawing at work of something resembling the internal profile of a hollowed stepped pulley, in which one of the steps was shown with a small pocket, perhaps for a form of key, milled into it. The pocket's size and 2mm corner radii were so small, and it was so far down the overall cavity, I could not imagine how it could be machined with any standard slot-drills.
