Turning a taper spindle collet
Home Forums Workshop Techniques Turning a taper spindle collet
  • #15543
    John McNamara
      @johnmcnamara74883
      Turning a taper spindle plug collet own its own lathe
      John McNamara
        @johnmcnamara74883
        Hi All
        Turning a taper spindle collet on its own lathe.
        This may have been posted before although I have not seen a post recently.
        I needed to make a MT3 and NT40 plug collet to fit directly in the spindle of the lathe.
        So a piece of stock was selected that was long enough to make the two with a 15mm extra allowance in case the taper did not fit first time and to allow for cutting them apart and facing The plug is about 65mm diameter at the widest point.
        The following cutting sequence was used.
        After measuring the taper with a protractor I set the top slide to match the taper. Then I mounted the three jaw chuck and I skimmed the diameter to remove the scale then bored a Half inch hole half way through from the tailstock then reversed the work piece and bored from the other end and creating a through hole, as it happens it was fairly true leaving a clearance hole for a 12mm all thread rod that would be used later to clamp the collet. next both ends of the piece were faced. Then after rechecking the material holding tight I made the first taper cut.
        Leaving the piece in the chuck I removed the chuck and tried the taper cut using a little marking blue. It was a little out so I nudged the top slide and reinstalled the chuck made another cut and tried again. This time it was (about) right. “That L Do” ! (something I do not often say)….. I removed the piece from the chuck and removed the chuck.
        Skim:
        Face:
        Continued next post…..
        Edited By John McNamara on 13/11/2011 05:12:02
        #77749
        John McNamara
          @johnmcnamara74883
          Continued from previous post……..
          From that point on I would hold the piece in position with the threaded rod only.
          I installed the piece in the spindle clamped it with the all thread drawbar and turned the other straight end. It was then a simple matter of adjusting the taper with the top slide angle until a perfect fit was obtained I used marking blue to check the fit. No more trying to juggle a heavy 8 inch chuck, Using the taper alone guarantees perfect concentricity. It also saves a lot of time to make two at once. To assist removing the collet I put a nut behind it to enable it to be driven out using the all thread rod as a driver
          once completed the piece was cut in half using the bandsaw and the pieces refaced and bored MT3 and INT40 as required. The fit was more than enough to hold the piece in position for facing and boring. I just tapped it in position with a plastic mallet to seat it. For extra precision I marked the collet to index a known point (a small screw) on the spindle.
          Chuck no longer required
          Second taper
          Ready to cut in two
          Cut on the bandsaw (A fiddly set up it was hard to grip)
          Ready to face and bore as required
          Cheers
          Edited By John McNamara on 13/11/2011 05:41:03
          #77755
          Richard Parsons
            @richardparsons61721
            John next time set your compound slide using a DTI. If you are going to a male taper use the rear of the taper in the Headstock. This will give you a good taper.
            If you have a taper which is a bit ‘wobbly’ then machine away the centre of the taper. You will get a good fit.
            Dick
            #77764
            John McNamara
              @johnmcnamara74883
              Agree Richard
              A good fit but not a perfect fit. There is the chance of a slight error due to the cut line being slightly different from the line measured on the taper by the indicator. Unless the match is perfect two different tapers will result, Marking blue and trial cuts will yield a very close to perfect result.
              It was easy to turn the work end for end and make tiny adjustments to the top slide. without having to manage a heavy chuck hanging on the end of the work. this is an industrial lathe, the chuck is 200mm diameter and weighs about 25 kg on its DIN back plate. It is almost impossible to “feel” that wobble with a heavy weight (Chuck) hanging on the end of it.
              Making a pair makes the job easy, in this case I wanted two anyway.
              The process would work for many different types of collets even very small ones. The advantage being that you are “fitting” them to their holder, then boring them in position. You do not have to stop at 2 you could cycle a dozen work pieces or more if needed. all perfectly fitted and bored in situ.
              Cheers
              Edited By John McNamara on 13/11/2011 10:20:20
              #489177
              Andy taylor 2
                @andytaylor2
                I realise this is a ancient thread but I am in need of creating some tapers I can use for tools on a small but very very rigid Taylor milling machine. What would the process be to create these please??
                #489182
                Emgee
                  @emgee
                  Is the Taylor a horizontal mill with an MT3 spindle ?
                  Emgee
                  #489183
                  Andy taylor 2
                    @andytaylor2
                    Posted by Emgee on 04/08/2020 15:43:33:
                    Emgee
                    No mate its a vertical with a spurious non standard taper.
                    taylor mk2
                    Edited By Andy taylor 2 on 04/08/2020 16:04:09
                    #489326
                    Martin Connelly
                      @martinconnelly55370
                      The link to lathes.co.uk says the taper is 23 degrees. I don't know if the spindle is bored for a draw bar. If it is then making an adaptor to use ER collets may be an option.
                      Martin C
                      #489337
                      Andy taylor 2
                        @andytaylor2
                        Posted by Martin Connelly on 05/08/2020 20:39:28:
                        Martin C
                        yes it does have a draw bar fitted. Its a very solid mill but I had a bridge port complate with tooling come up so I stopped worying about it. It reminded me when I read the thread about turning tapers. lol
