turcite slide valve
turcite slide valve
Home Forums Locomotives turcite slide valve
  • #2083
    duncan webster 1
      @duncanwebster1
      duncan webster 1
        @duncanwebster1
        A question for the tribologists
        according to my sums, the piston force on my latest loco is ~80 lbs, but the force pushing the slide valve onto its face is 82 lbs. I can't find values for friction of gunmetal on gunmetal, all the references quote bronze on steel. Values vary from ~0.08 dynamic to 0.16 static, both lubricated.
        Many moons ago I seem to remember people using stainless steel valves, or at least a stainless facing 1/8" thick like a picture frame silver soldered onto a bronze backing. I'm reluctant to use a solid carbon filled ptfe valve as the centre where the valve rod slot crosses the nut slot is only 50 thou thick and has 80 psi on one side.
        I have considered a turcite picture frame glued to a bronze backing, but the recommended glue is 2 pack epoxy, and I doubt that would stand the 160 C or more temperature.
        I know tradition has gunmetal valves on gunmetal cylinders, but the questions are
        1. would stainless facing be better
        2. anyone know of a glue for turcite which would stand steam temperature
        I'm about to email Trelleborg, but considering I'd only need a few sqins I don't suppose they will be all that interested
        #570011
        Jeff Dayman
          @jeffdayman43397
          Any way you could trap the turcite plate in a milled recess at the steam chest to cylinder block joint? If you could, the high temp epoxy would just need to seal the turcite to the cylinder face rather than securing it and sealing it. Just a thought.
          I know epoxy and JB Weld etc are supposedly rated to 500 deg F / 260 deg C but in my experience they do not perform well at high temps especially if steam is present.
          #570013
          Pete Rimmer
            @peterimmer30576
            I use Araldite 2013 but it's only good for 70DegC
            Loctite 9492/9497 would seem to fit your needs good for 180degC
            #570021
            HOWARDT
              @howardt
              Turcite is good for 80deg C and Moglice not much better. Facing with Peek would work.
              #570149
              duncan webster 1
                @duncanwebster1
                Thanks for the info, looks like Turcite is a non starter. I've looked into Peek, and it might be possible to make it out of solid, it's a lot stronger, but this peek says the heat deflection temp is 150-170C. Steam at 80 psi is ~160C
                I though of the recess idea, but I need to keep it flat as well, so it needs to be glued. However, a pusher each end is probably a good feature to take some of the shearing load if I do go for Peek facing. Stainless is looking good at present to avoid similar materials.
                I've made cylinders and steam chest, so I'm not looking for major rethinks.
                #570293
                old mart
                  @oldmart
                  What about some shim brass or bronze? That would glue and comes in plenty of different thicknesses.
                  Edited By old mart on 07/11/2021 14:01:00
                  #570322
                  David George 1
                    @davidgeorge1
                    Have you thought of using PTFE sheet it has a temperature range up to 260 deg C.
                    David
                    #570327
                      Posted by duncan webster on 06/11/2021 14:36:34:
                      I don't know what material they use, but IKEA does a range of silly-cheap kitchen utensils which appear to be heat resistant to such temperatures. The black ones appear to be particularly good.
                      Ref. https://www.ikea.com/gb/en/p/gnarp-3-piece-kitchen-utensil-set-black-30335841/
                      Edited By Michael Gilligan on 07/11/2021 17:57:53
                      #570470
                        Presumably of no interest to Duncan, but may be useful to someone:
                        The black plastic is rated 220°C [428°F], and is identified as >PA66(GF15)<
                        … whatever that might be.
                        It saws and files nicely, but I haven’t tried machining it
                        duncan webster 1
                          @duncanwebster1
                          According to the interweb PA66 is glass loaded nylon and is rated for 110C long term PA66
                          Following advice on another forum I'm going for Phos Bronze, sufficiently different in hardness to avoid any problems, although with decent lubrication no-one seems to have a problem with gunmetal on gunmetal
                          #570498
                            Posted by duncan webster on 08/11/2021 21:17:47:
                            For info. … It’s the GF15 bit that denotes the addition of Glass Fibres, PA66 being the matrix.
                          Home Forums Locomotives Topics
