Haven't got one at the moment, but have in the past. I used a paint tin about 6" dia, and rotated by a 1/6th hp shaded pole motor, these motors are not the best for long running(that's why I don't have one now) a 1/4 hp 1450 rpm induction motor will run for days. The drum should run at about 30-60 rpm. I used two rubber rollers, one driven, from a clothes wringer from an old wringer type washing machine, with the drum sat on top.
A hexagonal wooden drum is probably a better shape. The foundry I use in Christchurch uses ordinary concrete mixers.
Ian S C
Edited By Ian S C on 08/09/2015 10:55:04
