Andrew,the Rapid Turn is in a different league to the Duality. The notable difference being the motor size, wirh a 1 H.P. motor and a low and high belt position it should have plenty of grunt to tackle some of the larger jobs, though it has been bought mainly for making custom bolts and studs. The Duality didn't have the threading capability that this does.
Getting it up and running was not without problems,as already mentioned, the chuck came loose from the backplate while I was making the thingywatchamacallit. It took a while for it to dawn on me what was happening. I thought that it was some sort of low frequency chatter at first. I was able to get it tightened up without any problems but that sort of thing should have been checked before despatch.
Also the motor has been wired incorrectly and everything is running in reverse to what it should do, again an easy fix, just swap two wires over, but it should have been checked before despatch. Again it took a while to register with the grey matter that it was running the wrong way, short term I just went into the G-code and put in M-4 to get the correct rotational sense then when I had time I checked in the manual that comes with it and sure enough it confirmed my suspicions.
Apart from those niggles it is a great bit of kit and will prove worth while to me.
One thing I don,t like is the proximity to the front of the headstock casting of the two mounting slots in the baseplate. It is impossible to get an open jaw spanner onto the nuts on the Tee slot studs they are so close. I presume they are positioned here so that the attachment can be mounted as far back as possible on the mill table. This would be needed if you were doing any work that involved using a tailstock.
I will probably cut some extra holes in the baseplate and do away with the central hold down fitting because it is in direct alignment with the nose of the chuck and effectively steals 1" of throw.
I will post on progress when I get round to making some vernier timing sprockets for vintage motorcycles.
When I was playing with it making the thingywatchamacallit I didn't pay any attention to feeds and speeds, other than to go very conservatively with the DOC so that there was no chance of a stall out which used to happen regularly with the Duality.
P.S. I enjoy reading your gliding posts, I used to work for a drilling Manager that had a half share in a glider at Aboyne in Aberdeenshire, his partner in the share I believe was a british champion in aerobatics or long distance gliding. I marvelled at the distances that they used to achieve sometimes going as far south as Leicestershire on thermals only.
Another acquaintance used to fly gliders out of Millfield in Northumberland, he, like you used to fly the club tug aircraft, eventually this led to him obtaining a commercial pilots licence and he is now flying for one of the Major airlines.
My son is currently at Oxford Air Academy taking an ATPL. He is off to Phoenix in October for the flying part of the course. I have had to lend him the money to do it, hence me still working after retiring from the Oil Industry
