Trunch trojan
Trunch trojan
Home Forums Beginners questions Trunch trojan
  • #494372
    Arthur Goodwin
      @arthurgoodwin45738
      Hi Guys
      Just pondering on the best way to do the eccentric strap.
      Do i bore to size then split and use shims or should i split first and then clamp together with the bolts before boring.
      Thanks in advance
      Arthur
      Arthur Goodwin
        @arthurgoodwin45738
        Eccentric strap
        #494373
          I usually soft solder two bits of brass/bronze together, mill the steps at the sides so the bolts can be fitted, then bore and finally shape the outside before melting apart.
