Posted by Sam Longley 1 on 25/11/2016 16:18:25:
Posted by Neil Wyatt on 25/11/2016 09:01:22:
The 'stealth' motor needs a new rubber band.
Might by interesting to explain why these 'stealth' machines always have lots of flat surfaces. Imagine light or radar hitting a typical convex surface – the light is reflected away at all angles, with a flat surface it all bounces off in one direction so the foe has to be exactly aligned with the surface. Clearly other ships will never align with the stealth ship's angled surfaces and a plane or missile would have to fly directly towards the ship at exactly the right angle to get a steady signal.
It isn't unusual to see reflections of the sun on car windscreens from many miles away, yet imagine how hard it would be to use a mirror to exactly illuminate a spot at such a distance.
Edited By Neil Wyatt on 25/11/2016 09:06:51
if that was the case ( Curved surfaces etc etc) why is it that the radar reflector on my boat is made from flat surfaces which are inclined at 45 degrees from the horizontal or vertical ( thus directing the reflection away from the transmitter one would have thought)& not simply a circular ball that would always display a section of its surface directly at the transmitting radar?
& if it is that hard to direct a mirror why did Colonel Custer & co use them to signal to the rest of the cavalry in all the westerns ( up to the bit where he got an arrow through his hat that is !!) & why have I got one as a signalling mirror as standard equipment in my liferaft.
Because three plane surfaces at exactly 90-degrees create a shape that will reflect an incident beam back out the way it came; the same effect is used in various types of reflectors including the ones left behind by apollo missions as laser targets. They fit small reflectors like this to stealth aircraft when being used in civilian airspace (and its why the avoid 90-degree corners at all costs on stealth machines).
The sun's angular diameter seen from earth is 0.5 degrees, so the beam from a signalling mirror spreads at this angle. At a mile the beam becomes about fifteen yards across. A small spot to hit a target by chance, but possible to hit with a bit of skill. Proper heliographs used for signalling (where actual messages not just random flashes are needed) were equipped with sights for accurate setting up.
Little extra info I found when reading up on the F117 earlier – it was all flat plates because 1970s computers couldn't do the hard maths to design a stealth plane with curved surfaces.
