The tale I will relate might have some relevance to all those who use CAD to make diagrams and parts for projects. If nothing else it makes us think before issuing a drawing!
Many years ago I was gainfully employed by a large concern that designed and manufactured military equipment. My forte was a RF Design Engineer and I had several projects under my care, both in development and in full production. Once you release a product onto the shop floor it becomes your personal "enfant terrible" and can haunt you for as long as it remains in production.
One day I received a call from a production operative on the shop floor giving me a heads up that there was "trouble at mill" brewing. When I asked which product was the cause of the current trouble he told me. But that product had been running for years and never gave any problems. After the initial teething troubles whilst the operators learned how to assemble and test the new animal things ran smoothly. So I was very surprised to hear there was now a problem.
My informant said it went deeper than that as there was a possibilty that all the production over the last few years might be affected. Horror thoughts like vehicle recalls to replace some parts at great expense went through my mind! Did I stuff up when I designed it?
Then my informant let me down gently, the new inspector on the line had rejected all the production for the last week and nothing was going out of the door and they wouldn't accept the word of a "nobody" to tell them to release the product for shipment.
Well, I put on my running shoes and made haste to the shop floor. My office was in a separate building removed from the factory and it took me a few minutes to get there. When I arrived a huddle of concerned people were gathered around a large table with the last few days production stacked on it. Each and everyone one of the finished items had a red label attached with string which bore the depressing words "Rejected".
I asked who had rejected the items and was shown to the door of the new inspector. He was a polite but firm gentleman who told me he couldn't pass the items as they did not conform to the drawings he was issued with to inspect said items. I was gobsmacked!
I asked him to point out what deviation there was between the finished items and the drawings. He informed me the screw slots on the items did not correspond with the assembly drawings and since the two differed they were not exactly to drawings, hence they failed! When I asked if the items actually worked and met the specification he informed me that apart from the screw slot problems everything else was perfectly in order.
When I told him the screw slot orientation was merely diagramatical and not meant to imply the screw slots had to be exactly as drawn, he agreed. But he also pointed out that the inspection drawings did not say this!
Apparently the others had made the same noises but he dug his heels in and wanted it from the "Design Authority", which would be yours truly. I told him he was perfectly correct, the items offered for inspection indeed did not comply with the supplied inspection drawings and I would immediately issue a temporary change note so the items may be passed for shipment. In that case he told me as soon as he received a copy of the works order informing him that a change note was to be issued he would release the items to the shipping department.
Although I could have, and was quite entitled to, give him a verbal b*llocking" for wasting our time, that would have been the wrong thing to do. He had made a very valid point, which if he had made the suggestion through the normal channels would have most likely been ignored. He showed us that there was a valid point, as the customers also were issued with the same inspection drawings so they could check goods delivered conformed to specification and if they had troubled to inspect with as much care as our man did would have been quite correct to reject the delivered goods. This would have been a highly embarrassing situation.
Although this is a silly and trivial occurrence it made me think about how we often take things for granted and don't give sufficient thought to the consequences. The upshot of this little "trouble at mill" was a directive issued by the Chief Engineer that in future all assembly and inspection drawings must add a note that "Screw head slots are purely for indication purposes unless noted otherwise". Problem solved!
