I’ve bought a T8 x 2 Trapezoidal tap and was wondering about the Tapping drill size.
Online search is not helpful, one source told me 6.9mm which doesn’t seem right since an M8 x 1.25 has a 6.8 mm tap drill and a bigger pitch should mean a smaller minor diameter.
Another source which looked to be AI generated assured me that the correct tap drill size for a T8 trapezoidal thread is 3.3mm (screen capture attached in case you don’t believe me)
I found a formula online for imperial ACME tap drills.
Tap drill size for acme taps
Based on a 100% of thread as per ANSI to calculate tap drill size for acme taps.
step 1
1 Divided by TPI ( threads per inch)
step 2
subtract this amount from the OD. for pitches 10 and greater always add .005″ for the drill size for pitches less than 10 TPI take the amount from step 1 and multiply x.05 ( 5 %) and add this to the drill size. This is for 95% to 100% threads.
For my 8mm x 2 Trapezoidal in imperial would be .315 x 12.7tpi
1/12.7=.079
.315 – .079 = 0.236 +.005 = 0.241” = 6.12mm tap drill size
Does this seem sensible?
