Transport for Live Steaming
Home Forums Work In Progress and completed items Transport for Live Steaming
  • #477225
    Werner Schleidt
      @wernerschleidt45161
      Hello ,
      I had the honour to record a video of the transport for live steaming. Our street steamer colleage Jürgen had build a 4 inch Garret Traction Engine.
      He is an experienced builder and this is his third traction engine he worked on. He had build a 2 inch and a 3 inch Fowler. At about three years ago he came up with the news that he build a 4 inch Garret.
      As I was in his basement I thought this can not go out the door, but Jürgen made before all measurements to see the clearances. There were sometimes a bit small . He ordered an Autocrane to pull it out of the basement.
      The crane had been adjusted a second time to have more clearance on the roof of the house.
      It was a very interesting action. Now Jürgen have to make a driving seat and test the waterpump and make his first steam test. Hopefully we can see it this year in action.
      please enjoy the video
      Werner
      Edited By Werner Schleidt on 03/06/2020 13:59:13
      Werner Schleidt
        #477232
        Jim Butler 1
          @jimbutler1
          Nice work by Jurgen, building the engine and planning the move.
          Nice work by the crane driver.
          JimB
          #477243
          Harry Wilkes
            @harrywilkes58467
            Moved a few traction engines but this take the biscuit
            H
            #477247
            V8Eng
              @v8eng
              Even just watching I had quite a few hold your breath moments!
              Have to admire the skill levels of everybody involved, good looking engine too.
              #477861
              vic francis
                @vicfrancis
                Wow! Fantastic, on the back of the crane driver it says over 35 years experience! And it shows… great work Werner👍Another observation ; let your garden return to nature = productive work on your engine!
                #477962
                Werner Schleidt
                  Hello Vic Francis
                  to clarify i was only the guy with the camera . Jürgen with the brown shirt is the owner and builder of the Garret.
                  I saw it live , i saw it on the video several times , during editing and the whole video, but it is always amazing each time.
                  Werner
                  Edited By Werner Schleidt on 06/06/2020 13:53:49
                  #484224
                  Werner Schleidt
                    Hi all,
                    we made another steam rally . This time we had seven engines . Jürgen show the 4 inch Garret unfortunatly the engine was not in steam, because he had some trouble with his engine. In forward direction the excenter was sticky at his trial run a day before.It seems that the tolerances are very narrow.
                    On one take he is standing behind the engines he had built. We had a lot of fun and look to the the special corona mask muffler at the Diesel engine.
                    I hope you can enjoy it.
                    Werner
                    Edited By Werner Schleidt on 06/07/2020 09:59:07
                    #484238
                    Baz
                      @baz89810
                      Absolutely fantastic, lovely engine and a very skilled crane driver.
                      #499751
                      Werner Schleidt
                        Hi all,
                        we made another steam rally and Juergen brought, the first time in public, his 4 inch garret traction engine with him.
                        best regards
                        Werner
                        #499761
                        Jeff Dayman
                          @jeffdayman43397
                          Great video of your rally ! Like Juergen's Garrett, and your fire engine was running well too!
                          #510428
                          Steve Addy
                            @steveaddy35670
                            Thanks Werner, this has cheered me up as I thought I would have problems moving my loco when it is finished. At least it isn't in a basement!
                            Steve
                            #510543
                            Werner Schleidt
                              A short update. Jürgens engine is runnning with each driving better. Problems he had with the safety valve spring made of stainless steel. It is changing his characteristic over time . It was setting after compression and heating. A colleage calculate a new spring for him , made of better steel and this worked now very good. The valve seting showed that runing in made it more correct, but next year we look to some retunning after more run in. And we want to make with my electronic cylinder indication setup some measurements of the valve timing. I have to make a new displacement sensor with more possible displacement, because of his longer piston travel. In the Plettenberg discription is a part of cylinder indication showed.
                              With driving with his engine he found out that the water gauges are very difficult to see. The back of his boiler is painted in a dark colour and so there is less light. I made for him LED Spots to iluminate from the back side the water glasses. Now it is very good visible.
                              Werner
                              #510563
                              Ian Welford
                                @ianwelford58739
                                Forgive my german, checked by google so hopefully better.
                                Vielen Dank, das Sie dies mit uns tielen . Ein fantastisches Video eines herausfordernden Problem.
                                Schone Arbeit.
                                Ian
                                #510567
                                Oldiron
                                  @oldiron
                                  Great little steam rallies Werner. Thanks for sharing. I have missed all our UK rallies this year as they were all cancelled due to Covid. I hope next year they will be allowed.
                                  regards
                                  #510601
                                  Steviegtr
                                    @steviegtr
                                    Thanks for sharing. Brilliant little machines. Love the Fire tender.
                                    Steve.
