Posted by James Hall 3 on 13/02/2023 19:39:04:
Jason B: Ah, I hadn't thought of tramming the head with the locating pin removed, so that's a very helpful suggestion – having removed any misadjustment there I can proceed to check the column, as you say, with a known good square.
Tramming by adjusting the head is all very well but if the column was to be subsequently shimmed then the head would then be out of tram again. The column needs to be adjusted first, then the head. This pre-supposes that the machine has been manufactured with the spindle axis accurately parallel with the column Z axis, (which I would expect).
All quite a lot of bother for small return IMHO.
